I setup a LAB for vNexus Dashboard Fabric Controller, the Lab launched correctly, but when I started to login devbox, put username and password shown in lab guide, it is failed, can you check it for us?
Hi I encounter this kind of bug, i can't put my interface in monitoring mode using GUI.Nexus Dashboard Version 3.2.1iFabric ControllerVersion 12.2.2.241Is there a method to put my interface in monitoring mode?Thanks.
Hi Team,I’m trying to access the Nexus Dashboard Orchestrator (NDO) sandbox via Cisco DevNet, but I’m unable to find it in the current sandbox catalog. I’ve read about the ND v2.2 release and the availability of NDO for multi-site ACI policy testing,...
Looking at doing some api posts. Starting with ND 3.1, it seems a X-Csrf-Token header needs to be included. How does one get/create the X-Csrf-Token? what is the difference between a authcookie and cookie?
I was looking at the API details to create a VRF in NDFC. The schema details shows * next to what i assume would be mandatory values? I do not see the same details for the "vrfTemplateConfig" object. The string is required but are all the fields ...
I tried launching vNexus Dashboard Fabric Controller lab since two months and it was failedAlso I tried it yesterday and faced same issue , can you check lab environment and API calls !Something is wrong
data = {'op':'replace',"path": "/schemas/{Schema id}/templates/UAT-SDC/bds/Backup1_BD",'value':{'unicastRouting': False,'arpFlood': False}}response = requests.put(url="https://{ip}/mso/api/v1", headers=headers, json=data, cookies=cookies, verify= Fal...
Hello. I am trying to use the API "/appcenter/cisco/ndfc/api/v1/lan-fabric/rest/globalInterface" to create a loopback interface.API reference: API Reference (LAN) - Nexus Dashboard Fabric Controller API, Release 12.2.2 - Cisco DevNetThis is the JSON ...
Hello all, I am trying from some time to export Flow Telemetry data from our NDI installation. Running the NDI and accessing the information through the GUI is working fine, but the APIs seems to not working. What is the background? I would like to e...
Was using the api documentation to understand shutting/no shutting a NDFC managed switch interface. nd2.3/ndrc 12.1. https://xxx/apidocs/#operation/adminstatus the online example uses: { "operation": "shut", "interfaces": [ { "Serial Number":...
I've 3 ND physical appliances running. Mgmt and Data ports are connected to N9K-C93108-TC-FX3P leaf switches.On the VIC1455 adapter I've SFP-10G-T-X installed to connected the appliances data ports to the ACI fabric.My problem is that the Data ports ...
Nexus dashboard orchestrator POST API call to add CA cert using URL https://<hostname>/api/config/ndtrustecas/ generates "Error 500: internal server error". Error message says "illegal base64 data at input byte 0"It seems the API call is not acceptin...
Hi. Is there any documentation to develop and package a service for Nexus Dashboard? Would appreciate any pointers. Thanks .. Mahesh
Hello All, New to NDFC. Trying to use the API to create a network via postman. I have been unsuccessful to this point. I can login. I can get a list of existing network, but cannot create a network. May be my stupidity. Hopefully someone can po...
Hi, All Cisco ACI MSO REST API documentations mention that I can get into the swagger ui page, by logging into the orchestrator page, and then use this URL: <mso-ip>/docs/userdocs#/ Yet, after logging into the orchestrator, I got an "404 not found'" ...
| Subject | Author | Posted |
| 01-28-2026 04:31 PM | ||
| 01-03-2025 06:25 AM | ||
| 09-23-2022 02:57 PM |
