kdg1
Community Member
CAE:
UCS Quick Start Guide
Author: Kristin Duran, [email protected]
Table of Contents
Preface. 3
Introduction. 3
Prerequisites. 3
Sample Topology. 4
Managing UCS. 4
Console Connection. 4
UCS Manager GUI 5
UCS Manager CLI 7
Initial Setup Steps. 7
Setup Wizard (Management IP), etc. 7
Configure Network Connectivity. 9
Chassis Discovery Policy. 10
Server Ports. 11
LAN. 12
SAN. 13
Uplink Ports. 15
Perform Initial System Validation. 17
Validate Hardware. 17
Validate Software. 18
Create Pools. 19
Management IP Address Pools. 19
MAC Address Pools. 20
WWN Pools. 21
UUID Suffix Pools. 21
Policies. 22
Create & Associate Service Profiles. 22
Create a Service Profile using the Expert Wizard. 23
Associate Service Profiles to Server Blade. 29
Additional UCS Management Configuration (Optional) 30
DNS. 31
SNMP. 31
Syslog. 32
NTP. 33
TACACS. 33
Radius. 35
Backup Configuration. 36
Install an Operating System on a Blade. 38
Preface
The purpose of this document is to describe the basic steps required to minimally configure Cisco’s Unified Computing System (UCS).  Additional references to detailed Configuration Examples and TechNotes are provided within each section.  Comprehensive configuration guides can be found at the following location:
http://www.cisco.com/en/US/products/ps10281/products_installation_and_configuration_guides_list.html
This document assumes basic knowledge of the various UCS components, including:
  • UCS 6100 series Fabric Interconnects
  • UCS 2100 series Fabric Extenders
  • UCS 5100 series Blade Chassis
  • UCS B-Series Blade Servers
  • UCS Network Adapters
An elementary understanding of Local Area Network (LAN) and Storage Area Network (SAN) technologies is also assumed.
Introduction
Cisco UCS is a next-generation data center platform that:
  • Unites computing, networking, storage access, and virtualization into a cohesive system
  • Integrates a low-latency, lossless 10 Gb Ethernet unified network fabric with enterprise-class, x86-architecture servers
Information about UCS features and functionality can be found at http://www.cisco.com/go/ucs/.
Prerequisites
The following tasks should be completed, and all information collected prior to beginning:
  • Physical installation of the UCS components, including Blade Server Chassis and Fabric Interconnects. Detailed information is available within the following guides:
  • Physical connectivity directly between the Fabric Interconnect L1/L2 ports (for clustering purposes)
  • Physical connectivity between the Fabric Interconnects and Fabric Extenders
    • Document port assignments for Server and Uplink ports
  • IP address assignments for each Fabric Interconnect, and cluster IP address (must all be on the same subnet)
  • Management IP Addressing Scheme for individual server blades
  • MAC Address Scheme
  • WWNN and WWPN Scheme (if connected to a SAN)
  • VLAN Numbering Scheme
  • VSAN Numbering Scheme (if applicable)
  • Management Systems Information (Optional)
    • TACACS hosts and keys
    • RADIUS hosts and  keys
    • SNMP hosts and community strings
    • DNS domain suffix and server IP address
    • NTP hosts
    • Syslog hosts
Sample Topology
Below is an example of a typical UCS topology:
Managing UCS
Cisco UCS Manager is the management service for all components in a Cisco UCS instance. Cisco UCS Manager runs within the Fabric Interconnects. You can use any of the interfaces available within this management service to access, configure, administer, and monitor the network and server resources for each chassis connected to the Fabric Interconnects.
Cisco UCS Manager includes the following interfaces you can use to manage a Cisco UCS instance:
  • Cisco UCS Manager GUI (Accessible via HTTP and HTTPS)
  • Cisco UCS Manager CLI (Accessible via Telnet, SSH, or Console)
  • XML API
Almost all tasks can be performed in any of the interfaces, and the results of tasks performed in one interface are automatically displayed in another.
Console Connection
The console port is an RS-232 port with an RJ-45 interface.  The console port is an asynchronous (async) serial port; any device connected to this port must be capable of asynchronous transmission.  The following figure shows how to connect to the console port on the Cisco UCS 6100 Fabric Interconnect.
The console port parameters on the computer terminal (or console server) attached to the console port are as follows:
  • 9600 baud
  • 8 data bits
  • No parity
  • 1 stop bit
UCS Manager GUI
Cisco UCS Manager GUI is the Java application that provides a GUI interface to Cisco UCS Manager. You can launch and access Cisco UCS Manager GUI from any computer that runs a supported operating system and has HTTP or HTTPS access to the UCS 6100 series Fabric Interconnect.
Overview of Cisco UCS Manager GUI
This section provides a brief overview of the Cisco UCS Manager GUI.  The most commonly used areas include:
  • Navigation Pane—The Navigation pane provides a centralized navigation point for all components in the Cisco UCS system. When you choose a component in the Navigation pane, the object displays in the Work Pane.
Navigation Pane
The Navigation Pane has six tabs; Equipment, Servers, LAN, SAN, VM, and Admin.  Each tab includes these elements:
    • A Filter list of values that you can use to restrict the Navigation Pane display to a certain type of objects.
    • An expandable navigation tree that you can use to access all of the objects on that tab. An plus (+) icon next to an object indicates that the object has subcomponents.
  • Work Pane—The Work Pane displays details about the object selected in the Navigation Pane.
Work Pane
The Work Pane includes these elements:
    • A navigation bar that displays the path from the main object of the tab in the Navigation Pane to the selected object. You can click on any object in this path in order to display that object in the Work Pane.
    • A content area that displays tabs with information related to the object selected in the Navigation Pane. The tabs displayed in the content area depend upon the selected object. You can use these tabs in order to view information about the object, create new objects, modify properties of the objects, and examine the chosen object.
While performing configuration steps in the UCS Manager GUI, you will find that there are often multiple ways to perform the same task.  For example, you can right-click on an object in the Navigation Pane and select an action or you may be able to select that same action from the corresponding view in the Work Pane.  In many cases, you may also have the ability to drag and drop objects within the Navigation Pane.  As you get comfortable with the UCS Manager GUI, you can choose the method that best suits your work habits.
If you would like additional information on the UCS Manager GUI, see the document entitled “Use UCS Manager GUI to Manage Cisco UCS” on CCO.
UCS Manager CLI
The UCS Manager CLI is organized into a hierarchy of command modes, which often correspond to managed objects.  Managed objects represent physical and logical components within UCS, such as servers, processors, Service Profiles, and policies.
The create, enter, scope, and exit commands are used to navigate the object hierarchy.
More detailed information on navigating the UCS Manager CLI can be found in the Cisco UCS Manager CLI Configuration Guide, Release 1.x.
Initial Setup Steps
The first time that you access a Fabric Interconnect in a Cisco UCS instance, a setup wizard prompts you for the following information required to configure the system:
  • Installation method (GUI or CLI)
  • Setup mode (restore from full system backup or initial setup)
  • System configuration type (standalone or cluster configuration)
  • System name
  • Admin password
  • Management port IP address and subnet mask
  • Default gateway IP address
  • DNS Server IP address
  • Default domain name
  • Setup Mode
  • System Configuration Type
  • Management Port IP Address
Performing an Initial System Setup for the First Fabric Interconnect
The following procedure is used for the initial setup of the first Cisco UCS 6100 Fabric Interconnect.
  1. Connect to the console port.
  2. Power on the Fabric Interconnect.  You will see the power on self test messages as the Fabric Interconnect boots.
  3. When the unconfigured system boots, it prompts you for the setup method to be used. Enter console to continue the initial setup using the console CLI.
  4. Enter setup to continue as an initial system setup.
  5. Enter y to confirm that you want to continue the initial setup.
  6. Enter the password for the admin account.
  7. To confirm, re-enter the password for the admin account.
  8. Enter yes to continue the initial setup for a cluster configuration.
  9. Enter the Fabric Interconnect fabric (either A or B).
  10. Enter the system name.
  11. Enter the IP address for the management port on the Fabric Interconnect.
  12. Enter the subnet mask for the management port on the Fabric Interconnect.
  13. Enter the IP address for the default gateway.
  14. Enter the virtual IP address.
  15. Enter yes if you want to specify the IP address for the DNS server, or no if you do not.
  16. (Optional) Enter the IP address for the DNS server.
  17. Enter yes if you want to specify the default domain name, or no if you do not.
  18. (Optional) Enter the default domain name.
  19. Review the setup summary and enter yes to save and apply the settings, or enter no to go through the setup wizard again to change some of the settings.
If you choose to go through the setup wizard again, it will automatically provide the values you previously entered, and the values will appear in brackets. To accept previously-entered values, press the Enter key.
Performing an Initial System Setup for the Second Fabric Interconnect
The following procedure is used for the initial setup of the second Cisco UCS 6100 Fabric Interconnect.
Note: The Fabric Interconnect should detect the peer Fabric Interconnect in the cluster. If it does not, check the physical connections between the L1 and L2 ports, and verify that the peer Fabric Interconnect has been enabled for a cluster configuration.
  1. Enter y to add the subordinate Fabric Interconnect to the cluster.
  2. Enter the admin password of the peer Fabric Interconnect.
  3. Enter the IP address for the management port on the subordinate Fabric Interconnect.
  4. Review the setup summary and enter yes to save and apply the settings, or enter no to go through the setup wizard again to change some of the settings.
Login to UCS Manager GUI through HTTPS
Complete the following steps to access the UCS Manager GUI through HTTPS:
  1. In your web browser, type or choose the web link for Cisco UCS Manager GUI.
  2. The default web link is https://UCSManager_IP.
    1. If a Security Alert dialog box displays, click Yes in order to accept the security certificate and continue.
  3. On the Cisco UCS Manager page, click Launch. You can be prompted to download or save the .JNLP file, depending on your browser configuration.
If a Security dialog box displays, click Yes in order to accept the certificate and continue. If desired, you can check the box in order to accept all content from Cisco.
  1. In the Login dialog box, enter your User Name and Password.
  2. Click Login.
After launching UCS Manager for the first time, you will see the Fabric Interconnects appear in the Navigation Pane.  In order to have a view into the chassis, you will need to properly configure the Server Ports.  Once you have properly configured the Server Ports using the information in this document, the next step is configuring your VLANs and VSANs, and finally the Uplink Ports to the rest of your LAN.
The type of network connectivity that is supported is dependent on the adaptor that is installed on your individual blade servers.  Table 1 describes the available adaptors and their capabilities.
Table 1:  UCS Network Adaptors and Capabilities
Adaptor
Maximum vNICs
Maximum vHBAs
Failover Supported
82598KR
No
M71KR-E/M71KR-Q
Yes
M81KR
15 * (min. acknowledged links between Fabric Extender and Fabric Interconnect) – 2
Mix and match of Ethernet and Fibre Channel
Yes
With respect to the initial setup, the Chassis Discovery Policy serves one main purpose, which is to tell the system how many active links between the Fabric Extenders and Fabric Interconnects should be connected upon initial discovery of a chassis.  For example, if the Chassis Discovery Policy is set to “4-link” and a newly discovered chassis has anything other than four links, the chassis will be visible with the "unsupported-connectivity" configuration, and otherwise unusable until the correct number of links are added, or the policy is changed.
This is a mandatory step in the initial UCS configuration.
Configuration using UCS Manager GUI
To configure the Chassis Discovery Policy through the UCS Manager GUI:
  • Select the Equipment tab in the Navigation Pane
  • Select the Equipment object
  • In the Work Pane, select the Policies tab
  • Under Chassis Discovery Policy, select the number of links to be used by the chassis
  • Under Power Policy, select one of the following options:
    • non-redundant
    • n+1
    • grid
  • Click Save Changes
Configuration using UCS Manager CLI
To configure the Chassis Discovery Policy through the UCS Manager CLI:
FabricInterconnect-A# scope org
FabricInterconnect-A /org # scope chassis-disc-policy
FabricInterconnect-A /org/chassis-disc-policy # set action 4-link
FabricInterconnect-A /org/chassis-disc-policy* # commit-buffer
To verify after the change has been made:
FabricInterconnect-A /org/chassis-disc-policy # show
Chassis Discovery Policy:
    Description Qualifier  Action            Rebalance
                none       4 Link            User Acknowledged
Server Ports
The Fabric Interconnect has two types of ports: Server and Uplink Ports.  The Server Ports are what connect to the Fabric Extender on the chassis, and the Uplink ports are what connect to the upstream switch (the LAN).  For more detailed information on establishing this connectivity, please see the CCO TechNote entitled “Set up Connectivity between Fabric Extender and Fabric Interconnect in UCS”.
To configure Server Ports through the UCS Manager GUI:
  • Expand Fabric Interconnects > Fabric Interconnect A > Fixed Module > Unconfigured Ports
  • Right click on the desired port object
  • Select Configure as Server Port or select Configure as Server Port under Actions in the Work Pane
  • Repeat for each port you want configured as a Server Port
  • Repeat for Fabric Interconnect B
To configure Server Ports through the UCS Manager CLI:
FabricInterconnect-A# scope eth-server
FabricInterconnect-A /eth-server # scope fabric a
FabricInterconnect-A /eth-server/fabric # create interface 1 12
FabricInterconnect-A /eth-server/fabric/interface* # commit-buffer
FabricInterconnect-A /eth-server/fabric # show interface
Interface:
    Slot Id Port Id Admin State  Oper State   State Reason            Chassis
          1       1 Enabled      Up                                          3
          1      12 Enabled      Up                                          1
          1       2 Enabled      Up                                          3
          1       3 Enabled      Up                                          3
          1       4 Enabled      Up                                          3
          1       5 Enabled      Up                                          1
          1       6 Enabled      Up                                          1
          1       7 Enabled      Up                                          1
          1       8 Enabled      Up                                          1
LAN
In order for a blade server to pass Ethernet traffic over a particular VLAN, that VLAN must be created within UCS Manager, and then later associated with a vNIC.  It is possible to create VLANs that are unique to either Fabric Interconnect.  However, for the purposes of this document, we will create a Global VLAN, which is a VLAN that resides on both Fabric Interconnects.
A unique VLAN ID is required for each named VLAN.  Note that VLANs with IDs from 3968 to 4048 are reserved.
To configure VLANs through the UCS Manager GUI:
  • Select the LAN tab in the Navigation Pane
  • Expand LAN > LAN Cloud
  • In the Work Pane, select the VLANs tab
  • Click the + in order to begin the VLAN creation
  • Enter the following information in the Create VLAN dialog box:
    • In the Name field, enter a unique name for the VLAN
    • In the ID field enter the network ID assigned to the VLAN
  • Click OK
To configure VLANs through the UCS Manager CLI:
FabricInterconnect-A# scope eth-uplink
FabricInterconnect-A /eth-uplink # create vlan PerfEngineering 199
FabricInterconnect-A /eth-uplink/vlan* # commit-buffer
FabricInterconnect-A /eth-uplink/vlan #
FabricInterconnect-A /eth-uplink/vlan # show
VLAN:
    Name       VLAN ID    Fabric ID Native VLAN
    PerfEngineering
               199        Dual      No
For additional information on VLAN configuration with UCS Manager, see the document entitled “VLAN Configuration for Cisco UCS” on CCO.
SAN
If you are utilizing VSANs within your Storage Area Network, you must create a VSAN in UCS Manager, and later associate it to a vHBA.  Similar to a VLAN, a VSAN can either be Global or individual to a Fabric Interconnect. VLANs and VSANs differ in that each fiber uplink from UCS to its upstream SAN switch supports only one VSAN. This is specified as a property of the Uplink FC Port. While vNICs can support multiple VLANs, each vHBA can support only one VSAN.
To configure a global VSAN through the UCS Manager GUI:
  • Select the SAN tab in the Navigation Pane
  • Expand SAN > SAN Cloud
  • In the Work Pane, select the VSANs tab
  • Click the + in order to begin the VSAN creation
  • Enter the following information in the Create VSAN dialog box:
    • In the Name field, enter a unique name for the VSAN
    • In the ID field enter a valid VSAN ID.  This needs to match an ID in your Core SAN.
    • Add a VLAN ID that is used internally in order to carry FCoE
  • Click OK
To configure a global VSAN through the UCS Manager CLI:
FabricInterconnect-A# scope fc-uplink
FabricInterconnect-A /fc-uplink # create vsan PerfEngineering 199 299
FabricInterconnect-A /fc-uplink/vsan* # commit-buffer
FabricInterconnect-A /fc-uplink/vsan #
FabricInterconnect-A /fc-uplink/vsan # show
VSAN:
    Name       Id         FCoE VLAN  Fabric ID
    PerfEngineering
               199        299        Dual
Please see the TechNote entitled “LAN and SAN Connectivity for a Cisco UCS Blade” on CCO for additional information on configuring SAN connectivity in UCS.
Uplink Ports
Uplink Ethernet ports connect your Fabric Interconnects to the upstream LAN switches.  Uplink Fibre Channel ports connect your Fabric Interconnects to the upstream SAN switches.  The procedure to configure Uplink Ports is similar to configuring Server Ports.
Configuring Uplink Ethernet Ports using UCS Manager GUI
To configure Uplink Ethernet Ports through the UCS Manager GUI:
  • Drag the ports you want configured as Uplink Ports to the Uplink Ethernet Ports object
  • Click OK
Configuring Uplink Ethernet Ports using UCS Manager CLI
To configure Uplink Ethernet Ports through the UCS Manager CLI:
FabricInterconnect-A /eth-uplink # scope fabric a
FabricInterconnect-A /eth-uplink/fabric # create interface 1 20
FabricInterconnect-A /eth-uplink/fabric/interface* # commit-buffer
FabricInterconnect-A /eth-uplink/fabric/interface #
FabricInterconnect-A /eth-uplink/fabric/interface # exit
FabricInterconnect-A /eth-uplink/fabric # show interface
Interface:
    1          19         Enabled     Up
    1          20         Enabled     Up
For additional information on configuring Uplink Ports in a UCS environment, see the document entitled “UCS Uplink Ethernet Connection Configuration Example” on CCO.
Configuring Uplink FC Ports using UCS Manager GUI
To configure Uplink FC Ports through the UCS Manager GUI:
  • Expand Fabric Interconnects > Fabric Interconnect A > Expansion Module 2 > Uplink FC Ports
  • Select the FC port you want configured as an Uplink FC Port
  • In the Work Pane, under Actions, click Enable Port
  • Under Properties, set the VSAN to the proper VSAN for the uplink port
Configuring Uplink FC Ports using UCS Manager CLI
cae-ucs-rtp-B# scope fc-uplink
cae-ucs-rtp-B /fc-uplink # enter vsan VSAN100 100 100
cae-ucs-rtp-B /fc-uplink/vsan # create member-port a 2 8
cae-ucs-rtp-B /fc-uplink/vsan/member-port* #
cae-ucs-rtp-B /fc-uplink/vsan/member-port* # commit-buffer
cae-ucs-rtp-B /fc-uplink/vsan/member-port #
cae-ucs-rtp-B /fc-uplink/vsan/member-port # show
Member Port:
    Fabric ID Slot ID    Port ID    Oper State       State Reason Oper Speed
    A                  2          8 Sfp Not Present  SFP not present
        Indeterminate
Once you have configured Server and Uplink ports, it is a good idea to validate the hardware has been properly discovered and that you are running the desired version of firmware.
Validate Hardware
The Hybrid Display provides an excellent visual depiction of the components within your UCS deployment, including the connected ports.
Validation using UCS Manager GUI
To validate the system hardware through the UCS Manager GUI:
  • Expand Equipment > Chassis
  • Select the appropriate Chassis object
  • In the Work Pane, select the Hybrid Display tab
Chassis
Fabric Interconnect
Fabric Extender
Blade Server
To view the hardware details of a blade server through the UCS Manager GUI:
  • Expand Servers
  • Select the blade server object you want to view
  • In the Work Pane, select the Inventory tab
Look at the Inventory tab to see what type of hardware is installed in your system.  Make note of the Adaptor.
Validate Software
While not mandatory, it may be desirable to note the firmware versions that are running on the various components within UCS.
To validate system software through the UCS Manager GUI:
  • In the Work Pane, select the Firmware Management
Validation using UCS Manager CLI
To validate the system software through the UCS Manager CLI:
FabricInterconnect-A # scope firmware
FabricInterconnect-A /firmware # show image
Name                                Type                 Version         State
diag-nuova-or-4.0.0.062.bin         Unspecified          4.0(1a)         Active
ucs-2100.1.0.1.6.gbin               Iom                  1.0(1.6)        Active
ucs-2100.1.1.0.158i.gbin            Iom                  1.1(0.158i)     Active
ucs-2100.1.1.0.215.bin              Iom                  1.1(0.215)      Active
ucs-2100.1.1.0.217a.bin             Iom                  1.1(0.217a)     Active
ucs-2100.1.1.0.282.bin              Iom                  1.1(0.282)      Active
ucs-2100.1.1.0.89c.gbin             Iom                  1.1(0.89c)      Active
For additional information on software management and validation in UCS, see the following documents on Cisco.com:
Create Pools
One of the key benefits of UCS is stateless computing.  Stateless computing refers to the ability to move the “identity” of one server to another using the concept of Service Profiles.  In order to take advantage of stateless computing, traditionally derived (burned-in) addresses would need to be individually assigned to each Service Profile, which functions as a type of abstraction layer between the hardware and the Operating System. This assignment can either be done on a per-Service Profile basis or by creating a Pool of addresses and allowing UCS to decide which address to assign.
Examples of resources that can be pooled include Management IP Addresses, MAC Addresses, WWNN, WWPN, and UUID values.  Additional information about pools can be found in the CCO TechNote entitled “Create Pools to Simplify Blade Management in Cisco UCS”.
The Management IP Address pool facilities the assignment of a management IP address to an individual blade server.  The Management IP Address is used for Serial Over LAN (SOL) or IPMI access.  Note that the Management IP Address pool currently has to be on the same subnet as the Management interface of the UCS Manager.
To configure Management IP Address Pools through the UCS Manager GUI:
  • Select the Admin tab in the Navigation Pane
  • Expand All > Communication Management
  • Select the Management IP Pool (ext-mgmt)
  • In the Work Pane, under Actions, click Create Block of IP Addresses
  • Enter the requested information to create the block of management IP addresses
  • Click OK
To configure Management IP Address Pools through the UCS Manager CLI:
FabricInterconnect-A /org # scope ip-pool ext-mgmt
FabricInterconnect-A /org/ip-pool # create block 172.18.100.10 172.18.100.60 172.18.100.1 255.255.255.0
FabricInterconnect-A /org/ip-pool # commit-buffer
FabricInterconnect-A /org/ip-pool # show
IP Pool:
    Name                 Size       Assigned
    ext-mgmt                     50         10
MAC Address Pools
A MAC Address Pool eases the administrative burden of assigning individual MAC addresses to each Service Profile.
To configure MAC Address Pools through the UCS Manager GUI:
  • Expand LAN > Pools > root
  • Right click the MAC Pools object and select Create MAC Pool
  • Give the pool and Name and Description, then click Next
  • Click Add to add a range of MAC addresses
  • Specify the First MAC Address and the Size of the pool
  • Click OK
  • Click Finish
To configure MAC Address Pools through the UCS Manager CLI:
FabricInterconnect-A /org # create mac-pool MyMACPool
FabricInterconnect-A /org/mac-pool* # create block 00:25:B5:40:00:00 00:25:B5:40:00:31
FabricInterconnect-A /org/mac-pool/block* # commit-buffer
FabricInterconnect-A /org/mac-pool # show
MAC Pool:
    Name                 Size       Assigned
    MyMACPool                    50          1
WWN Pools
WWNN and WWPN Pools ease the administrative burden of assigning individual WWNN and WWPN addresses to each Service Profile.  In a typical UCS deployment, you would create fairly large WWN pools.  After they are assigned to a Service Profile, which is then assigned to a blade server, you would note the WWN assignment and configure your SAN accordingly.
To configure WWN Pools through the UCS Manager GUI:
  • Expand SAN > Pools > root
  • Right click the WWNN Pools object and select Create WWNN Pool
  • Click Add to add a block of WWN addresses
  • Specify the First WWN Address and the Size of the pool
  • Click OK
  • Click Finish
To configure WWN Pools through the UCS Manager CLI:
FabricInterconnect-A /org # create wwn-pool WWNTEST node-wwn-assignment
FabricInterconnect-A /org/wwn-pool* # create block 20:00:00:25:b5:00:00:00 20:00:00:25:b5:00:00:31
FabricInterconnect-A /org/wwn-pool/block* # commit-buffer
FabricInterconnect-A /org/wwn-pool # show
WWN Pool:
    Name                 Purpose             Size       Assigned
    MyWWNNPool           Node Wwn Assignment         50          0
UUID Suffix Pools
The utilization of UUID Suffix Pools within a Service Profile eliminates the need to manually configure the UUID of the server associated with the Service Profile.
To configure UUID Suffix Pools through the UCS Manager GUI:
  • Select the Servers tab in the Navigation Pane
  • Expand Servers > Pools > root
  • Right click the UUID Suffix Pools object and select Create UUID Suffix Pool
  • Click Add to add a block of UUID Suffixes
  • Specify the First UUID Suffix and the Size of the pool
  • Click OK
  • Click Finish
To configure UUID Suffix Pools through the UCS Manager CLI:
FabricInterconnect-A /org # create uuid-suffix-pool MyUUIDPool
FabricInterconnect-A /org/uuid-suffix-pool* # create block 0000-000300000001 0000-000300000032
FabricInterconnect-A /org/uuid-suffix-pool/block* # commit-buffer
FabricInterconnect-A /org/uuid-suffix-pool # show
UUID Suffix Pool:
    Name                 UUID Prefix        Size     Assigned
    MyUUIDPool           8C1D5178-8C02-11D9       50          1
Policies
The use of Policies is not mandatory during the initial UCS configuration.  However, it is important to be aware that there are various Policies that can be created and applied to Service Profiles.  For detailed information about this feature, please see the CCO TechNote entitled “Configure Chassis and Server Discovery Policies for Cisco UCS”.
You should be somewhat familiar with the concept of Service Profiles from the previous sections.  The Service Profile, or logical server, is the fundamental backbone of the stateless capabilities within UCS.  The Service Profile represents a logical view of a single blade server, without the detailed knowledge of the underlying hardware. The profile object contains the server personality, for example, the values contained in the pools that were created in the previous steps.
Service Profiles can be created manually, cloned from an existing Service Profile, or created in batch using a Service Profile Template.  This guide will focus on the manual creation of a Service Profile.  For more detailed information on Service Profiles, please see the following CCO TechNotes:
This document will guide you through the creation and association of a single Service Profile to a blade server.  Please note that this process should be repeated for each blade server in the chassis.
While a Service Profile can exist that inherits the identity of the blade server, we will focus on creating a Service Profile that overrides the server’s identity, which is required for stateless computing.
In this procedure, we will use the Expert Wizard to create a new Service Profile:
  • Select the Servers tab In the Navigation Pane
  • Expand Servers > Service Profiles
  • Select the root object
  • In the Work Pane, under Actions, click Create Service Profile (expert)
  • In the Name field, enter a unique name that you can use to identify the Service Profile
  • If applicable, choose the UUID Pool you created in the previous step from the from the UUID Assignment drop-down list
  • In the Description field, enter a description of this Service Profile
  • Click Next
Storage vHBA Definition
  • From the Local Storage drop-down list, choose one of the RAID options.  This applies to the local disks (if applicable)
  • Leave the Scrub Policy as <not set>
  • If applicable, choose the WWNN Pool you created in the previous step from the WWNN Pool drop-down list
  • If applicable, name your vHBAs and select the VSANs that were created in the previous step
  • Click Next
Networking vNIC Definition
  • Select the Expert option as shown
  • Click Add
Create exactly one vNIC in the profile for each port you would like to make accessible to your blade server’s operating system.
Use Table 1 in the Configure Network Connectivity section of this document to determine the maximum number of vNICs that are supported with your exact hardware configuration.
Once you click Add, the “Create vNICs” pop-up window appears
  • Name the vNIC accordingly
  • If applicable, choose the MAC Address Pool you created in the previous step from the from the MAC Address Assignment drop-down list
  • Select the VLAN you created in the previous step from the drop-down list
  • Choose whether this will be the Native VLAN
  • Once it is completed, click OK, then Next
vNIC/vHBA Placement
vNIC/vHBA Placement specifies the mezzanine card on which the vNICs and vHBAs are placed.  This step of the setup wizard is only applicable on the B250 full width blade server, which has multiple mezzanine cards.
Define Boot Policy/Order
  • You can either choose from the Boot Policy drop-down list or choose Create Boot Policy
  • Select order of the boot sequence as shown below in the Create Boot Policy pop-up window.
  • You can choose to boot first from CD Rom, Local Disk, or your SAN.
  • On the Server Assignment screen, leave Server Assignment set to Assign Later
  • Click Next
  • Leave the settings on the Operational Policies page set to their default
  • Click Finish to create the Service Profile.
A 1:1 mapping of Service Profiles to blade servers can exist.  You cannot assign a Service Profile to more than one blade server at any given time.
To bind a Service Profile through the UCS Manager GUI:
  • Expand Servers > Service Profiles > root
  • Right click the Service Profile you want to bind with a blade server and select Change Service Profile Association
  • Under Server Assignment in the dialog box that appears, choose Select existing Server
  • In the list of available servers, select the blade server you want to bind the Service Profile with
  • Click OK
To bind a Service Profile through the UCS Manager CLI:
FabricInterconnect-A /org # scope service-profile MyServiceProfile
FabricInterconnect-A /org/service-profile # associate server 1/1
FabricInterconnect-A /org/service-profile* # commit-buffer
FabricInterconnect-A /org/service-profile # show
Service Profile:
    Service Profile Name Type              Server  Assignment Association
    MyServiceProfile     Instance          1/1     Assigned   Associating
The items listed below are optional, but common configuration settings that would normally be configured as part of an initial UCS deployment.
DNS
Configure a DNS server that will be used to resolve hostnames to IP addresses within UCS.
More detailed information on configuring DNS can be found in the following CCO TechNote: Configure the DNS Server for Cisco UCS.
To configure DNS through the UCS Manager GUI:
  • Select the DNS Management object
  • In the Work Pane, under Actions, click Specify DNS Server
  • Enter the IP address of the DNS server and click OK.
To configure your UCS to utilize a DNS Server with address 192.168.1.1:
FabricInterconnect-A# scope system
FabricInterconnect-A /system # scope services
FabricInterconnect-A /system/services # create dns 192.168.1.1
FabricInterconnect-A /system/services* # commit-buffer
FabricInterconnect-A /system/services # show dns
Domain Name Servers:
IP Address: 192.168.1.1
SNMP
Use this section to help you configure SNMP for both polling and sending Traps.  UCS supports SNMP Version 2c and Version 3, but this document will guide you through configuring Version 2c.
For detailed information on the information that can be gathered via SNMP from UCS, please see the following link on CCO: MIB Quick Reference for Cisco UCS Manager, Release 1.x.
To configure SNMP through the UCS Manager GUI:
  • Select the Communication Services object
  • In the Work Pane, under SNMP, change the Admin State to enabled
  • Set the Community value
  • Under SNMP Traps, click +
  • Enter the IP Address and Community for the trap destination
  • Click OK
To set the SNMP community to ‘public’ (Note: It is recommended that you choose a different community other than ‘public’ for both SNMP and SNMP Traps), execute the following:
FabricInterconnect-A# scope monitoring
FabricInterconnect-A /monitoring # set snmp community public
FabricInterconnect-A /monitoring # show snmp
    Admin State: Disabled
    Port: 161
    Community: public
To set the SNMP-Trap community to ‘public’, execute the following
FabricInterconnect-A /monitoring # create snmp-trap 192.168.1.1
FabricInterconnect-A /monitoring/snmp-trap* # set community public
FabricInterconnect-A /monitoring/snmp-trap* # commit-buffer
FabricInterconnect-A /monitoring/snmp-trap # show detail
SNMP Trap:
    Hostname: 192.168.1.1
    Port: 162
    Community: public
    Version: V2c
    V3 Privilege: Noauth
To enable SNMP after the settings have been configured:
FabricInterconnect-A /monitoring # enable snmp
    Admin State: Enabled
    Port: 161
    Community: public
Syslog
UCS has standard syslogging capabilities and can write to a local and remote facility.  More detailed information on configuring Syslog can be found in the following CCO TechNote:
Set up Syslog for Cisco UCS.
To configure Syslog through the UCS Manager GUI:
  • Expand All > Faults, Events and Audit Log
  • Select the Syslog object
  • In the Work Pane, under Local Destinations, enable or disable logging to the Console, Monitor, and File
  • Under Remote Destinations, configure up to 3 syslog servers by clicking enabled under Admin State for each server
  • Specify the logging Level, Hostname (or IP Address), and Facility
FabricInterconnect-A /monitoring # set syslog remote-destination server-1 hostname syslog1.cisco.com state enabled
FabricInterconnect-A /monitoring* # commit-buffer
FabricInterconnect-A /monitoring # show syslog
console
    state: Disabled
    level: Critical
monitor
    state: Disabled
    level: Critical
file
    state: Enabled
    level: Critical
remote destinations
    Name     Hostname             State    Level         Facility
    Server 1 syslog1.cisco.com    Enabled  Critical      Local7
    Server 2 none                 Disabled Critical      Local7
    Server 3 none                 Disabled Critical      Local7
NTP
UCS can synchronize its clock with an NTP server on your network.  Use the following procedure to configure this feature.
To configure NTP through the UCS Manager GUI:
  • Expand All > Timezone Management
  • In the Work Pane, under Actions, click Add NTP Server
  • Enter the hostname (or IP address) of the NTP server
  • Click OK
To configure your UCS to utilize an NTP Server with address 192.168.1.1:
FabricInterconnect-A /system/services # create ntp 192.168.1.1
FabricInterconnect-A /system/services # show ntp
NTP Servers:
TACACS
Before configuring UCS for TACACS support, please ensure that your TACACS Server has been pre-configured with the appropriate key and that the individual IP addresses of each Fabric Interconnect have been added accordingly.  Note that the TACACS request will be sourced from the individual IP address of each Fabric Interconnect.
For more details on configuring UCS for TACACS authentication, as well as the corresponding configuration required on the CiscoSecure ACS Server (if applicable), see the CCO TechNote entitled Setup TACACS Authentication for Cisco UCS.
To configure TACACS through the UCS Manager GUI:
  • Expand All > User Management
  • Select the TACACS+ object
  • In the Work Pane, under Actions, click Create TACACS+ Provider
  • Enter the Hostname (or IP address), Order, and Key of the TACACS+ server
  • Click OK.
Once a TACACS+ server has been configured, enable TACACS authentication using the following steps:
  • Select the Authorization object
  • In the Work Pane, set Default to tacacs
Set the TACACS Server IP address to 192.168.1.1:
FabricInterconnect-A# scope security
FabricInterconnect-A /security #
FabricInterconnect-A /security/tacacs # create server 192.168.1.1
FabricInterconnect-A /security/tacacs/server* # set key
Enter the key: <enter the key here – it will not display on the screen>
Confirm the key: <confirm>
FabricInterconnect-A /security/tacacs/server* # set port 49
FabricInterconnect-A /security/tacacs/server* # commit-buffer
FabricInterconnect-A /security/tacacs/server #
FabricInterconnect-A /security/tacacs/server # show detail
AAA server:
    Hostname or IP address: 192.168.1.1
    Order: 1
    Port: 49
    Key: ****
Verify and change Authentication settings:
To verify current settings:
FabricInterconnect-A /security # show authentication
Console authentication: Local
Default authentication: Local
Role Policy For Remote Users: Assign Default Role
Set the default authentication method to TACACS for remote connections (SSH, Telnet, HTTP, HTTPS):
FabricInterconnect-A /security # set authentication default tacacs
FabricInterconnect-A /security* #commit-buffer
Default authentication: Tacacs
Radius
Before configuring UCS for RADIUS support, please ensure that your RADIUS Server has been pre-configured with the appropriate key and that the individual IP addresses of each Fabric Interconnect have been added accordingly.  Note that the RADIUS request will be sourced from the individual IP address of each Fabric Interconnect.
For more details on configuring UCS for RADIUS authentication, as well as the corresponding configuration required on the CiscoSecure ACS Server (if applicable), see the CCO TechNote entitled Set up RADIUS Authentication for Cisco UCS.
To configure RADIUS through the UCS Manager GUI:
  • Select the RADIUS object
  • In the Work Pane, under Actions, click Create RADIUS Provider
  • Enter the Hostname (or IP address), Order, and Key of the RADIUS server
  • Click OK
Once a RADIUS server has been configured, enable RADIUS authentication using the following steps:
  • In the Work Pane, set Default to radius
To configure RADIUS through the UCS Manager CLI:
FabricInterconnect-A /security # scope radius
FabricInterconnect-A /security/radius # create server 192.168.1.1
FabricInterconnect-A /security/radius/server* # set key
Enter the key:
Confirm the key:
FabricInterconnect-A /security/radius/server* # commit-buffer
FabricInterconnect-A /security/radius/server#
FabricInterconnect-A /security/radius/server # show detail
AAA server:
    Order: 1
    Port: 1812
    Key: ****
Set the default authentication method to RADIUS for remote connections (SSH, Telnet, HTTP, HTTPS):
FabricInterconnect-A /security # set authentication default radius
Default authentication: Radius
A UCS configuration backup takes a snapshot of all or part of the system configuration and exports the backup file to a location on your network.  The backup can be performed while the system is up and running. The backup operation only saves information from the management plane. It does not have any impact on the server or network traffic.
To create a backup operation through the UCS Manager GUI:
  • Select the All object
  • In the Work Pane, under Actions, click Backup
  • In the Backup dialog box, under Actions, click Create Backup Operation
  • Set the Admin State to enabled
  • Enter the Protocol, Hostname, Remote File, User, and Password information
  • Click OK
  • Click OK
To create a backup operation through the UCS Manager CLI:
cae-ucs-rtp-B# scope system
cae-ucs-rtp-B /system # create backup sftp://[email protected]///[email protected]/ all-configuration enabled
cae-ucs-rtp-B /system/backup* # set remote-file MyUCSBackup
cae-ucs-rtp-B /system/backup* # set password
Password:
cae-ucs-rtp-B /system/backup* # commit-buffer
cae-ucs-rtp-B /system/backup # show
Backup:
    Hostname   Type                  User       Protocol Administrative State Description
    backup.cisco.com
               All Configuration     admin      Sftp     Enabled
Installing an operating system is the last step in the initial configuration of UCS.  This step is not covered in this document, but great detail on this topic can be found in the following in the chapter entitled “Installing an OS on a Server” within the Cisco UCS Manager GUI Configuration Guide, Release 1.x on CCO.
