cisco_admin1
Level 3
Level 3
With Ajay Kumar and Telmo Pereira
Ajay Kumar Telmo Pereira
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn and ask questions about configuration and troubleshooting the Cisco Application Control Engine (ACE) load balancer with Cisco expert Ajay Kumar and Telmo Pereira. The Cisco ACE Application Control Engine Module for Cisco Catalyst 6500 Series Switches and Cisco 7600 Series Routers is a next-generation load-balancing and application-delivery solution. A member of the Cisco family of Data Center 3.0 solutions, the module: Helps ensure business continuity by increasing application availability Improves business productivity by accelerating application and server performance Reduces data center power, space, and cooling needs through a virtualized architecture Helps lower operational costs associated with application provisioning and scaling
Ajay Kumar  is a customer support engineer in the Cisco Technical Assistance Center in Brussels, covering content delivery network technologies including Cisco Application Control Engine, Cisco Wide Area Application Services, Cisco Content Switching Module, Cisco Content Services Switches, and others. He has been with Cisco for more than four years, working with major customers to help resolve their issues related to content products. He holds DCASI and VCP certifications.
Telmo Pereira is a customer support engineer in the Cisco Technical Assistance Center in Brussels, where he covers all Cisco content delivery network technologies including Cisco Application Control Engine (ACE), Cisco Wide Area Application Services (WAAS), and Digital Media Suite. He has worked with multiple customers around the globe, helping them solve interesting and often highly complex issues. Pereira has worked in the networking field for more than 7 years. He holds a computer science degree as well as multiple certifications including CCNP, DCASI, DCUCI, and VCP
Remember to use the rating system to let Ajay know if you have received an adequate response.
Ajay and Telmo might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation on the Data Center sub-community discussion forum Application Networking shortly after the event.
This event lasts through July 26, 2013. Visit this forum often to view responses to your questions and the questions of other community members.
