cisco_admin1
Level 3
Level 3
Read the bioWith Sivakumar Sukumar
Welcome to the Cisco Support Community Ask the Expert conversation. This is an opportunity to learn and ask questions about configuration and troubleshooting the Cisco Application Control Engine (ACE) loadbalancer with Sivakumar Sukumar. The Cisco ACE Application Control Engine Module for Cisco Catalyst 6500 Series Switches and Cisco 7600 Series Routers is a next-generation load-balancing and application-delivery solution. A member of the Cisco family of Data Center 3.0 solutions, the module:
  • Helps ensure business continuity by increasing application availability
  • Improves business productivity by accelerating application and server performance
  • Reduces data center power, space, and cooling needs through a virtualized architecture
  • Helps lower operational costs associated with application provisioning and scaling
Sivakumar Sukumar is an experienced support engineer with the High Touch Technical Support content team, covering all Cisco content delivery network technologies including Cisco Application Control Engine (ACE), Cisco Wide Area Application Services (WAAS), Cisco Content Switching Module, Cisco Content Services Switches, and other content products. He has been with Cisco for more than 2 years, working with major customers to help resolve their issues related to content products. He holds CCNP and DCASI certification.
Remember to use the rating system to let Sivakumar know if you have received an adequate response.
Sivakumar might not be able to answer each question due to the volume expected during this event. Remember that you can continue the conversation on the Data Center sub-community discussion forum shortly after the event. This event lasts through August 24, 2012. Visit this forum often to view responses to your questions and the questions of other community members.
