Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Are you new to coding? This session will get you started using REST, Python and JQuery.
We will cover coding basics and create some simple examples that retrieve, parse and display JSON data using the Cisco APIC-EM REST API’s and the NeXt Javascript framework. Bring your laptop and we’ll help you get your own development environment set up so you can code with us.
Taught by Cisco DevNet Community Manager Amanda Whaley
