hapresto
Introduction
I’ve been long waiting for the latest version of IOS-XE to ship, and on April 13th IOS-XE 16.5 “Everest” posted to https://cisco.com/go/software for the ISR, ASR, and CSR routing platforms (still to come are the Catalyst Switching lines).  The “Everest" release of IOS-XE is jam packed with new programmability features that I think everyone will agree are excellent additions as network programmability is becoming a mainstream topic for us all.  Some of the highlights of this release include
  • A modular approach to YANG Data Models for Cisco IOS-XE Features (ISR, CSR, ASR)
  • Support for Zero Touch Provisioning (ZTP) for Day 0 infrastructure setup (ISR)
  • New Application Hosting capabilities provided by a Linux Guest Shell (ISR)
  • Ability to develop and execute Python scripts On-Box (ISR)
Note: Not all IOS-XE platforms support all features in release 16.5.  Future software releases will extend features to other platforms.
In future blog posts I’ll dive deeper into all of these features, but today we’re going to look at the new Python execution capabilities.
Python and GuestShell
The ability to execute Python code directly on an end device is a part of the Application Hosting capabilities provided by GuestShell.  We’ll go deeper into GuestShell on another day, but for now it is important to understand just some of the basics.  GuestShell is a containerized Linux runtime that can be enabled on your IOS-XE device.  On the ISR 4000 platforms, Guest Shell provides a CentOS 7 environment in which you can install and run applications, such as Python scripts.  From within Guest Shell you and your applications have access to the networks of the host platform, bootflash, and IOS CLI.  Guest Shell is isolated from the underlying host software to prevent interference of the core network functions of the device.
And I can’t go any further without mentioning that though a new feature to IOS-XE, Open NX-OS has offered Guest Shell and Python for awhile now.  In fact the feature within IOS-XE is modeled after how it works within NX-OS so much of what we’ll look at here applies to NX-OS as well!
Guest Shell Quick Start
Enough talk… let’s get into some config and code!  For this blog post I am using an ISR 4431 running 16.5.1b.  The router was recently upgraded to 16.5 and has little other configuration in place.  Before we can jump into doing something interesting with Python, we need to get Guest Shell up and running.
Step 1: Enable IOX
IOX is the manager that handles guest shell and other 3rd party applications in IOS-XE.
dev4431-1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
dev4431-1(config)#iox
dev4431-1#show iox
Virtual Service Global State and Virtualization Limits:
Infrastructure version : 1.7
Total virtual services installed : 0
Total virtual services activated : 0
Machine types supported   : KVM, LXC
Machine types disabled    : none
Maximum VCPUs per virtual service : 2
Resource virtualization limits:
Name                         Quota     Committed     Available
system CPU (%)                  75             0            75
memory (MB)                    512             0           512
bootflash (MB)                1000             0          1000
IOx Infrastructure Summary:
IOx service (CAF)    : Running
IOx service (HA)     : Not Running
IOx service (IOxman) : Running
Libvirtd             : Running
It should take only a few minutes for IOX start up.  The HA service may not start on all platforms.
Step 2: Enable Guest Shell
From enable mode, you can now start the Guest Shell.  It will take a few minutes to finish the startup procedure.
dev4431-1#guestshell enable
Management Interface will be selected if configured
Please wait for completion
dev4431-1#show app-hosting list
App id                           State
guestshell                       RUNNING
dev4431-1#
Step 3: Setup Guest Shell for Network Access - DNS
To do anything of real interest, you need to tell Guest Shell what DNS servers to use.  We do this by setting them within “/etc/resolv.conf” just like a typical Linux OS.
! Log into Guest Shell from the router
dev4431-1#guestshell run bash
[guestshell@guestshell ~]$
# Use echo to add your DNS Server to the file.  Here I use Open DNS.
[guestshell@guestshell ~]$ echo "nameserver 208.67.222.222" | sudo tee --append /etc/resolv.conf
[guestshell@guestshell ~]$ cat /etc/resolv.conf
# Test to see if things are working by using pip to install “requests”
[guestshell@guestshell ~]$ sudo -E pip install requests
Collecting requests
  Downloading requests-2.13.0-py2.py3-none-any.whl (584kB)
    100% |################################| 593kB 610kB/s
Installing collected packages: requests
Successfully installed requests-2.13.0
Note… if your environment requires Proxy Servers to access the internet, you will need to configure them within Guest Shell as well as DNS.
Success!
Alright, we are all set and ready for some Python Magic!
Quick Exploration of Python on IOS-XE
As Guest Shell is based on Cent OS 7, it comes with Python 2.7.5 pre-installed.
[guestshell@guestshell ~]$ python --version
Python 2.7.5
Along with Guest Shell, a few Python libraries are included for interacting with the underlying IOS platform.  Below I give a show how we can use them send commands to IOS and process the results.
Python 2.7.5 (default, Jun 17 2014, 18:11:42)
[GCC 4.8.2 20140120 (Red Hat 4.8.2-16)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> from cli import *
>>> ios_version = cli("show version")
>>> print(ios_version)
Cisco IOS XE Software, Version 16.05.01b
>>> ip_interfaces = cli("show ip int bri")
>>> print(ip_interfaces)
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0/0   10.192.81.2     YES DHCP   up                    up
GigabitEthernet0/0/1   unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/2   unassigned      YES NVRAM  down                  down
GigabitEthernet0/0/3   unassigned      YES NVRAM  down                  down
GigabitEthernet0       10.192.81.91    YES DHCP   up                    up
VirtualPortGroup0      192.168.35.1    YES manual up                    up
>>> # Now I’ll configure the description on an interface
>>> conf_snippet = '''interface GigabitEthernet0/0/2
...                     desc Configured by Python'''
>>> config_result = configure(conf_snippet)
>>> config_result
[ConfigResult(success=True, command='interface GigabitEthernet0/0/2', line=1, output='', notes=None), ConfigResult(success=True, command='   desc Configured by Python', line=2, output='', notes=None)]
>>> # The clip function runs a command and prints the results
>>> clip("show run int GigabitEthernet0/0/2")
Building configuration...
Current configuration : 132 bytes
description Configured by Python
no ip address
shutdown
media-type rj45
negotiation auto
end
>>> exit()
If you prefer Python 3, you can install it like you would on any Cent OS 7 device.
[guestshell@guestshell ~]$sudo -E yum -y install https://centos7.iuscommunity.org/ius-release.rpm
[guestshell@guestshell ~]$sudo -E yum -y install python35u-3.5.3
[guestshell@guestshell ~]$python3.5 --version
Python 3.5.3
Let’s do something interesting
Okay, running live Python commands on a router is interesting, but not very powerful all by itself.  Let’s take a look at how we can combine this new feature with EEM for new and interesting options.  With the addition of Python and Guest Shell, you can now have EEM execute a Python Script as an action.  This provides the power of Python, with the event driven actions of EEM… Awesome!   For this example we’ll take a step into “Chat Ops” and our Router send a Spark message every time the configuration is changed.
Step 1:  Create a Spark Bot Account for our Router
In order to send a message with Spark, our router will need an account to use.  Rather than create a full account for every device, I’ll just create a Bot under my own Spark Account for this router.  From https://developer.ciscospark.com, I create a new bot account.  I grab the Authentication Token because I’ll need that for my script.
Step 2:  The Python Code
For this demo, I created a very simple Python Script that can be used to send a message to someone.  Here is the script.
from ciscosparkapi import CiscoSparkAPI
if __name__=='__main__':
    # Use ArgParse to retrieve command line parameters.
    from argparse import ArgumentParser
    parser = ArgumentParser("Spark Check In")
    # Retrieve the Spark Token and Destination Email
    parser.add_argument(
        "-t", "--token", help="Spark Authentication Token", required=True
        "-e", "--email", help="Email to Send to", required=True
    args = parser.parse_args()
    token = args.token
    email = args.email
    message = "**Alert:** Config Changed"
    api = CiscoSparkAPI(access_token=token)
    api.messages.create(toPersonEmail=email, markdown=message)
I am using the very handy CiscoSparkAPI Python module to send the message, so we’ll need to pip install that first.
[guestshell@guestshell ~]$ sudo -E pip install ciscosparkapi
Now I create  “scripts” folder in the bootflash to store this and other future scripts.
[guestshell@guestshell ~]$ mkdir /bootflash/scripts
Because this directory is on bootflash, I could create the script from my local machine and upload it using any available method to get it onto the box.  For now, I’m just going to use “vi” from within Guest Shell to create the script.
[guestshell@guestshell ~]$ cat /bootflash/scripts/spark_checkin.py
    token = args.token
    email = args.email
Before I tie it into EEM, let’s test it real quick to make sure it works.  The script uses the common “argparse” module for Python to take in command line arguments for the token, email to send to, and message to send.
[guestshell@guestshell ~]$ python /bootflash/scripts/spark_checkin.py -t OTJjNGM1MGItZjUUyZjM0Y2ViYzc5Mjg3MGUzNTQtYTM0 -e hapresto@cisco.com
And I do indeed get the message in Spark!
Step 3: Connecting to EEM
First I drop out of guest shell and get back into IOS.
[guestshell@guestshell ~]$ exit
exit
dev4431-1#
Next I configure the EEM Applet to use the script.
dev4431-1#config t
dev4431-1(config)#event manager applet GUESTSHELL-CONFIG-CHANGE-TO-SPARK
dev4431-1(config-applet)#event syslog pattern "%SYS-5-CONFIG_I: Configured from"
dev4431-1(config-applet)#action 0.0 cli command "en"
dev4431-1(config-applet)#action 1.0 cli command "guestshell run python /bootflash/scripts/spark_checkin.py -t OTJjNGM1MGItZjUUyZjM0Y2ViYzc5Mjg3MGUzNTQtYTM0 -e hapresto@cisco.com"
dev4431-1(config-applet)#exit
dev4431-1(config)#exit
Now each time I make a configuration change, I receive the notification in Cisco Spark.  This is a very basic implementation of the “Chat Ops” idea, but highlights how quick and easy this type of thing can be leveraged with very little time, or programming skill needed.
With the power of Python, I could use ncclient and NETCONF to leverage the model drive programmability options under the hood as an alternative to the CLI options we looked at earlier this post.
Summing Up!
Wow... I hope you found this article enjoyable and got you thinking about how you might leverage this new capability of IOS-XE.  If you’d like to test out the spark_checkin.py code a little closer you can find it, along with many other Python samples posted in on GitHub in the https://github.com/CiscoDevNet/python_code_samples_network repository.
If this kind of thing has you interested, be sure to join us at Cisco Live 2017 in Vegas.  We've several sessions in DEVNET discussing the new programmability features of IOS-XE and all our platforms.  A few suggestions to take a look at include:
DEVNET-1694 - Supercharge the Network with Python On IOS-XE
DEVNET-2556 - DevNet Workshop - Dive into Leveraging Python on IOS-XE
DEVNET-1695 - Application Hosting in IOS-XE
DEVNET-2557 - DevNet Workshop - Hand On - Application Hosting in IOS-XE
DEVNET-2589 - DevNet Workshop - Hands-On - Solving Problems with Application Hosting and Guestshell
DEVNET-2102 - DevNet Workshop - Network Programmability with NXOS Using Guest Shell
Also, we've got new Learning Labs and Sandboxes planned to provide more great hands on options and info for you at anytime.
What will you use this new feature for?  Leave a note in the comments, or tweet me @hfpreston
32 Comments
jaemlee
Great posting.
I've upgraded os to 16.5.1b   @ ISR4321.
but couldn't execute iox command.
Is there any prerequites to execute that command?
hapresto
Thanks!
There shouldn't be.  I haven't got a 4321 specifically to test it out.  Can you run these commands and drop the output back here?
show ver | inc Software|License Level|memory
dir bootflash: | inc free
And do you have any other containers running?  Maybe a KVM Container from pre-16.5?
jaemlee
Thanks Harold.
This is what the result with command. And I didn’t run any other container --;;
BR-1#
BR-1#show ver | inc Software | License Level|memory
Cisco IOS Software , ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.5.1b, RELEASE SOFTWARE (fc1)
cisco ISR4331/K9 (1RU) processor with 1684579K/6147K bytes of memory.
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3223551K bytes of flash memory at bootflash:.
BR-1#
BR-1#conf t
BR-1(config)#iox
% Invalid input detected at '^' marker.
BR-1(config)#exit
BR-1#guest
BR-1#guestshell
iox feature is not enabled
BR-1#
Jaemi Lee
SYSTEMS ENGINEER.SALES
jaemlee@cisco.com<mailto:jaemlee@cisco.com>
Tel: +82 2 3429 8092
Cisco Systems, Inc.
5F, ASEM Tower 517, Yeongdong-daero Gangnam-gu
SEOUL
06164
Korea, Republic Of
cisco.com
Think before you print.
This email may contain confidential and privileged material for the sole use of the intended recipient. Any review, use, distribution or disclosure by others is strictly prohibited. If you are not the intended recipient (or authorized to receive for the recipient), please contact the sender by reply email and delete all copies of this message.
Please click here<http://www.cisco.com/web/about/doing_business/legal/cri/index.html> for Company Registration Information.
hapresto
Following up for any who might have the same problem.  Guest Shell requires 8G of RAM on to function.  ISR4321s default to 4G so you need the RAM upgrade to use Guest Shell.
Thanks!
Hank
yawming
Is guest supported in CSRv ?
I see the command available in CSR1000v - Cisco IOS XE Software, Version 16.05.01b
But there is no iox
csrv1000-31#guestshell ?
  destroy  Disable and uninstall the guest shell service package
  disable  Disable the guest shell service package
  enable   Enable the guest shell service
  run      Execute/run program in the guest shell
csrv1000-31#guestshell enable
hapresto
Unfortunately Guest Shell is NOT in 16.5 on the CSR.  BUT it is being considered for a future release.  Stay tuned and I'll be sure to let everyone know when it ships!
Hank
pakulz001
Community Member
Hello, Harold. I have 8GB RAM on my ISR4321, but oix not enabled too.
Router#sh ver | i Software|License Level|memory
Cisco IOS Software [Everest], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.5.1b, RELEASE SOFTWARE (fc1)
cisco ISR4321/K9 (1RU) processor with 3732579K/6147K bytes of memory.
8388608K bytes of physical memory.
Router#
Router#
Router#dir bootflash: | i free
3249049600 bytes total (2525495296 bytes free)
Router#
Router#
Router#conf t
Router(config)#oix
Router(config)#end
Router#
*May  1 14:14:34.739: %SYS-5-CONFIG_I: Configured from console by console
Router#guestshell
Router#guestshell enable
Router#
hapresto
can you check your steps?  You have "Router(config)#oix" in your output.  It should be..
Router(config)#iox
Thanks!  Hank
pakulz001
Community Member
Thanks, Hank. I resolve this problem.
https://developer.cisco.com/media/iox-dev-guide-11-28-16/platforms/platform-isr4k/
For activate iox need type command:
iox-ISR4321-03(config)#virtual-service // go to the virtual-service submode
iox-ISR4321-03(config-virt-serv-global))#signing level unsigned // enable
installation of unsigned app iox-ISR4321-03(config)# iox-ISR4321-03(config)#iox
// enable the IOx CAF process
2017-05-01 17:24 GMT+03:00 Harold Preston III <community@cisco.com>:
Cisco Communities <https://communities.cisco.com/>
Introducing Python and Guest Shell on IOS-XE 16.5
new comment by Harold Preston III
<https://communities.cisco.com/people/hapresto> - View all comments on
this blog post
<https://communities.cisco.com/community/developer/blog/2017/04/17/introducing-python-and-guest-shell-on-ios-xe-165#comment-30013>
hapresto
I'm glad you got it working, but that's odd.. you shouldn't have needed to make that adjustment to make it work..
pakulz001
Community Member
Mybe it's need only for ISR4321. I do not have other Cico IOS XE router for
check it.
Tell me, plz. When planned run Bash Shell in IOS XE, similarly NX-OS?
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/programmability/guide/b_Cisco_Nexus_9000_Series_NX-OS_Programmability_Guide_7x/Bash.html
In Russia Cisco Connect conference this was announced.
Sorry for my English.)
2017-05-02 22:17 GMT+03:00 Harold Preston III <community@cisco.com>:
this blog post
<https://communities.cisco.com/community/developer/blog/2017/04/17/introducing-python-and-guest-shell-on-ios-xe-165#comment-30025>
bruce.maurer
Frequent Visitor
Frequent Visitor
Great article.  I jumped right in with a lab 4451-x and had things going nicely in a closed environment.  The only piece I'm not clear on, and can't seem to find the right document to set the guestshell interface to gain network access.  I'm not new to the bash shell, but I must have missed a step somewhere.
[guestshell@guestshell ~]$  ifconfig eth0
eth0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        ether 58:97:bd:1c:55:7f  txqueuelen 1000  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
        device memory 0xa6180000-a61a0000
bruce.maurer
Frequent Visitor
Frequent Visitor
Found the fix in the following document:
Very nice addition to the platform.
hapresto
Excellent!  I missed your first posting as it got lost in email.  Glad you were able to nail it down!
vishal-patil
Level 3
Level 3
I have the same question about how to get network access (internet) to guestshell. Unfortunately, the document link no longer valid.
Vishal
