Cisco UI Toolkit
RSTFbx
Community Member
Hi - The Cisco UI toolkit was retired in 2019 and I am looking for its replacement.  I am working to build an Angular based app and was wondering where to find the latest Cisco UI framework/developer resources.
The NeXt UI Framework is still available on GitHub under CiscoDevNet. It's described as an HTML5/JavaScript toolkit for network web applications, featuring topology visualization. While not specifically Angular, you might be able to integrate components from it. Find it here: https://github.com/CiscoDevNet/NeXt.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
