DevNet / CCNA
nal0
Community Member
I am not sure if this is the right place to ask this type of question.
I am currently studying for my CCST Networking certification, and I am considering, afterwards, to pursue DevNet Associate. My question is, if this is the right path or right thing to do. As far as I know, if someone wants to take the DevNet path, you should first consider taking the CCNA before, so you can get these fundamental networking skills, but you still get fundamental networking skills in the CCST.
In short, do you need to take the CCNA before DevNet, or is it enough with the CCST and then DevNet?
@nal0 While the CCNA is traditionally recommended before DevNet, it's not strictly required. The CCST provides a solid foundation, and you can supplement it with additional DevNet-focused learning.
Good luck!
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Good luck!
@bigevilbeard Thank you so much! That clarifies it for me.
