Devnet Grails Runtime Exception
AbbasDadou
Dears,
I am trying to access Cisco  Developer network and i get a Runtime exception when i try to login. I used to login to devnet with no issue. can you please help. Below please find the exception i got
Error Details
Error 500: Executing action [login] of controller [com.kpi.dp.pingfederate.SSOController] in plugin [dp-cisco] caused exception: Runtime error executing action
Servlet: grails
URI: /grails/SSO/login.dispatch
Exception Message: Column 'address_id' cannot be null
Caused by: Column 'address_id' cannot be null
Class: LoginFilter
At Line: [113]
Code Snippet:
Stack Trace
com.mysql.jdbc.exceptions.jdbc4.MySQLIntegrityConstraintViolationException: Column 'address_id' cannot be null
at com.mysql.jdbc.Util.handleNewInstance(Util.java:411)
at com.mysql.jdbc.Util.getInstance(Util.java:386)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1041)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:4237)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:4169)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:2617)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2778)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2825)
at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:2156)
at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedStatement.java:2459)
at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedStatement.java:2376)
Best Regards,
Abbas
17 Replies 17
amoherek
Hi Abbas,
Thank you for bringing this to our attention. We are aware of the error and are working on resolving the issue.
Adrienne
Do you know when this error will be corrected?  I need to access a support ticket as soon as possible.
Here is the error i get when i try to login to DevNet:
Servlet: grails
  Exception Message: object references an unsaved transient instance - save the transient instance before flushing: com.kpi.dp.core.company.DpCompany
Caused by: object references an unsaved transient instance - save the transient instance before flushing: com.kpi.dp.core.company.DpCompany
Class: LoginFilter
At Line: [113]
org.hibernate.TransientObjectException: object references an unsaved transient instance - save the transient instance before flushing: com.kpi.dp.core.company.DpCompany
at org.grails.datastore.gorm.GormStaticApi$_methodMissing_closure2.doCall(GormStaticApi.groovy:101)
at com.kpi.dp.core.company.DpCompany.getRoles(DpCompany.groovy:172)
at com.kpi.dp.core.company.DpCompanyCoreService.addRolesToCompany(DpCompanyCoreService.groovy:1595)
at GrailsMelodyGrailsPlugin$_closure4_closure16_closure17.doCall(GrailsMelodyGrailsPlugin.groovy:184)
at com.kpi.dp.cisco.pdb.SppDetailsUtility.updateCompanyRoles(SppDetailsUtility.groovy:188)
at com.kpi.dp.cisco.pdb.SppDetailsUtility.updateCompany(SppDetailsUtility.groovy:141)
at com.kpi.dp.cisco.pdb.SppDetailsUtility.createCompany(SppDetailsUtility.groovy:101)
at com.kpi.dp.cisco.pdb.SppDetailsUtility.createOrUpdateCompany(SppDetailsUtility.groovy:92)
at com.kpi.dp.cisco.pdb.SppDetailsUtility.updateUser(SppDetailsUtility.groovy:63)
at com.kpi.dp.core.user.DpSSOService.createOrUpdateUser(DpSSOService.groovy:179)
at com.kpi.dp.core.user.DpSSOService.createSSOUser(DpSSOService.groovy:143)
at com.kpi.dp.core.user.DpSSOService.loginUser(DpSSOService.groovy:54)
at com.kpi.dp.pingfederate.SSOController$_closure1.doCall(SSOController.groovy:81)
at grails.plugin.cache.web.filter.PageFragmentCachingFilter.doFilter(PageFragmentCachingFilter.java:198)
at grails.plugin.cache.web.filter.AbstractFilter.doFilter(AbstractFilter.java:63)
at net.bull.javamelody.JspWrapper.invoke(JspWrapper.java:150)
at net.bull.javamelody.JdbcWrapper$DelegatingInvocationHandler.invoke(JdbcWrapper.java:285)
at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:202)
at net.bull.javamelody.MonitoringFilter.doFilter(MonitoringFilter.java:180)
at com.kpi.dp.core.traffic.PageHitFilter.doFilter(PageHitFilter.groovy:60)
at com.kpi.dp.core.security.filter.ForceCompanyRegistrationFilter.doFilter(ForceCompanyRegistrationFilter.groovy:38)
at com.kpi.dp.core.security.filter.TcAgreeSSOFilter.doFilter(TcAgreeSSOFilter.groovy:56)
at com.kpi.dp.core.security.filter.TcAgreeFilter.doFilter(TcAgreeFilter.groovy:55)
at grails.plugin.springsecurity.web.filter.GrailsAnonymousAuthenticationFilter.doFilter(GrailsAnonymousAuthenticationFilter.java:53)
at com.kpi.dp.core.user.LoginFilter.doFilter(LoginFilter.groovy:113)
at grails.plugin.springsecurity.web.authentication.RequestHolderAuthenticationFilter.doFilter(RequestHolderAuthenticationFilter.java:49)
at grails.plugin.springsecurity.web.authentication.logout.MutableLogoutFilter.doFilter(MutableLogoutFilter.java:82)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:724)
Patricia,
I work with DevNet development team. The DevNet development team is working on the issue. Please confirm the following info:
Cisco ID = Patricia134
email associated with Cisco ID = [email protected]
Also, have you tried to log into DevNet since Friday? I believe you have based on the timestamp of your last post.
Hi Richard,
I still face the issue since last Wednesday. I tried to login everyday since then and always got the same error. Can you please help.
Best Regards,
Abbas
Hi Richard,
Yes i still get the error.  I tried to login one minute ago.  Yes you have the right informations.
It work as of now.
Thanks for your help
You are welcome.
Kayo Granillo
Project Manager
[email protected]
Phone:
Cisco Systems Limited
US
Cisco.com<http://www.cisco.com>
Think before you print.
This email may contain confidential and privileged material for the sole use of the intended recipient. Any review, use, distribution or disclosure by others is strictly prohibited. If you are not the intended recipient (or authorized to receive for the recipient), please contact the sender by reply email and delete all copies of this message.
For corporate legal information go to:
http://www.cisco.com/web/about/doing_business/legal/cri/index.html
It works now. Thank you for your help and support
Hi Richard,
The issue occur again since yesterday. I could not login to DevNet. Can you please help.
Best Regards,
Abbas
I am looking into this issue.
A few questions regarding the issue.
  1. Can you copy the grails error and send it to me?
  2. Is NEXTLEVEL TECHNOLOGY SYSTEMS-NTS a partner company with Cisco?
  3. Have you recently changed your Cisco id or email associated with your Cisco id?
Hi Richard,
Kindly find below my answers.
Error Details
Servlet: grails
Class: LoginFilter
At Line: [113]
Code Snippet:
     at com.mysql.jdbc.PreparedStatement.executeUpdate(PreparedStatement.java:2360)
     at net.bull.javamelody.JdbcWrapper.doExecute(JdbcWrapper.java:403)
     at net.bull.javamelody.JdbcWrapper$StatementInvocationHandler.invoke(JdbcWrapper.java:128)
     at com.kpi.dp.cisco.pdb.SppDetailsUtility.updateCompany(SppDetailsUtility.groovy:147)
     at com.kpi.dp.cisco.pdb.SppDetailsUtility.createCompany(SppDetailsUtility.groovy:109)
     at com.kpi.dp.cisco.pdb.SppDetailsUtility.createOrUpdateCompany(SppDetailsUtility.groovy:101)
  1. Is NEXTLEVEL TECHNOLOGY SYSTEMS-NTS a partner company with Cisco?
Yes
  1. Have you recently changed your Cisco id or email associated with your Cisco id?
No.
Best Regards,
Abbas
Hi Richard,
Kindly any update.
Best Regards,
Abbas
Hello I get the same error message -- is there a resolution for this?
Login: eklingman
error:
Error Details
Servlet: grails
Exception Message: Cannot invoke method trim() on null object
Caused by: Cannot invoke method trim() on null object
Class: LoginFilter
At Line: [113]
Code Snippet:
Stack Trace
java.lang.NullPointerException: Cannot invoke method trim() on null object
     at com.kpi.dp.cisco.pdb.SppDetailsUtility.updateCompany(SppDetailsUtility.groovy:121)
     at com.kpi.dp.cisco.pdb.SppDetailsUtility.createOrUpdateCompany(SppDetailsUtility.groovy:99)
