External error in the NED implementation for device
kumarabhi84
Visitor
Getting below error during sync-from operation on production device:
  "tailf-ncs:output": {
    "result": false,
    "info": "External error in the NED implementation for device ABCD: failed to enter admin mode, missing 'connection admin password' ned-setting"
Please help me with the solution.
5 Replies 5
Marcel Zehnder
kumarabhi84
Visitor
Hi Marcel, I'm using same Authgroup for other device it working fine.
I reconfigured the authgroup on falied device but still getting same error.
Below I have mentioned authgroup config:
admin@ncs(config)# show full-configuration devices authgroups
devices authgroups group ABC_AUTH
default-map same-user
default-map same-pass
devices authgroups group default
default-map remote-name admin
default-map remote-password $9$1b+siFPe/S4aqJHVHaudackxyzzao=
Is this a CLI or NETCONF NED? Can you login with the authgroups credentials to the box via CLI or NETCONF?
kumarabhi84
Visitor
Yes, I am using cli NED. And also able to logged into the device using authgroup credentials.
On the device in question using ssh and the authgroup credentials do you get a priv level 15 session?
