NX-API tacacs authorization issues
We have some nexus 9Ks in our environment and I have been testing out the NX-API functionality. One of the things I've noticed is that command authorization in tacacs really seems to have an effect. Especially as it pertains to configuration commands. I've disabled the authorization command in tacacs and now I am able to make configurations changes through the api. The way I wrote the script I'm using my own tacacs user creds so my thought was that the privileges should have been there.
I will do more digging,  being new to using APIs I didn't know what to expect when it came to command authorization. Honestly I didn't fully understand what an API configuring the box would look like from the devices perspective.
Curious if anyone has had a similar experience?
Thanks.
Todd
8 Replies 8
Jason Pfeifer
The NXAPI credentials and authorization should match what is set for CLI commands as well.  If you are noticing
different behavior you may be hitting a bug.  Are you noticing different behavior if you run the same command on CLI as the same user?
No the commands work if I do it in the cli. The first switch 10.13.0.1 has the following tacacs command removed
aaa authorization config-commands default group TacServer
The second switch 10.13.0.2 does not.
Results from running the python script.
Username : xxxxxx
Password :
10.13.0.1
                "jsonrpc":      "2.0",
                "result":       null,
                "id":   1
                "jsonrpc":      "2.0",
                "result":       null,
                "id":   2
                "jsonrpc":      "2.0",
                "result":       null,
                "id":   3
10.13.0.2
                "jsonrpc":      "2.0",
                "result":       null,
                "id":   1
                "jsonrpc":      "2.0",
                "error":        {
                        "code": -32602,
                        "message":      "Invalid params",
                        "data": {
                                "msg":  "Error: AAA authorization failed AAA_AUTHOR_STATUS_METHOD=16(0x10)\n"
                "id":   2
                "jsonrpc":      "2.0",
                "error":        {
                        "code": -32008,
                        "message":      "Command not ran due to previous failures"
                "id":   3
You can see the commands worked on 10.13.0.1. Failed on 10.13.0.2. These are the commands I'm running.
  payload=[{"jsonrpc": "2.0","method": "cli", "params": {"cmd": "config t", "version": 1}, "id": 1},
             {"jsonrpc": "2.0", "method": "cli", "params": {"cmd": "interface loopback 12","version": 1},"id": 2},
             {"jsonrpc": "2.0", "method": "cli", "params": {"cmd": "description nxapi script test","version": 1},"id": 3}]
10.13.0.1 - output
lab-cmh1-dc-ds3#    sh run int loop12
!Command: show running-config interface loopback12
!Time: Mon Mar 23 15:37:28 2015
version 6.1(2)I3(1)
10.13.0.2 - did not implement the commands from the nxapi script.
Here's the commands entered manually.
lab-cmh1-dc-ds4# config t
Enter configuration commands, one per line.  End with CNTL/Z.
lab-cmh1-dc-ds4(config)# int loopback 12
lab-cmh1-dc-ds4(config-if)# description nxapi script test
lab-cmh1-dc-ds4(config-if)# end
lab-cmh1-dc-ds4# sh run int loop12
!Time: Mon Mar 23 15:35:49 2015
version 6.1(2)I3(1)
Looking buggy to me.
Todd
It will be interesting to see the reason given by the TACACS+ server for denying authorization for those commands, plus debug output on the switch for TACACS+.
I'm running into this issue as well..same response from Nexus..
Curious if you found anything out? Thanks.
Wow. Thanks for the information. Good to finally have some closure on the issue,.
Based on what I've heard the fix is coming in April(ish) in 8.1.x of NXOS
