NX-API with Nexus 7000
tmkobayashi
I recently started using the nx-api with Nexus 7000 and I noticed that it takes a long time to get a response. That are times that I don't even get a return. I tested using the Sandbox and through python rest calls. I'm trying simple show commands such as "show ip int brief".
Did anyone have had such problem? Is there anything I can do?
ai01
What version of NX-OS are you running? What's the CPU utilization on the switch? Also can you tell us a bit more about the setup? Is this switch in a remote location? What is the delay between the management IP of the switch and the machine from where you are running the python script?
