Python script - unable to set encrypted preshared key
MrNox
Frequent Visitor
Frequent Visitor
Hi there,
I'm trying to set an encrypted preshared key on a C9200 (ver 17.06.05) with a python script.
When executing the following script
import cli
cli.configurep([
	"password encryption aes",
	"key config-key password-encrypt MYKEY"
I get the following output :
Line 1 SUCCESS: password encryption aes
Line 2 SUCCESS: key config-key password-encrypt MYKEY
However the second line is not configured.
Did I miss something ?
Try
import cli
cli.enable()
cli.configure(["crypto key generate rsa general-keys modulus 1024"])
config = [
cli.configure(config)
 The cli.configure() method takes a list of configuration commands and executes them in config mode.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
First try, I had to remove ,cli.enable() because of this : "AttributeError: module 'cli' has no attribute 'enable''"
After a second try, the rsa key pairs were generated successfully. The "password encryption aes" command was executed successfully but the "key config-key password-encrypt MYKEY" command still fails to work. When trying to set an encrypted key for radius or tacacs+ servers, I receive invalid key error messages. This suggests that encrypted preshared key is not set properly.
Ruben Cocheno
@MrNox
Has this been resolved?
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
