VXML on 2811
svetladm
Frequent Visitor
Frequent Visitor
Greetings,
Cisco 2811 with current version of OS 12.4(24) T4, and Cisco Unified Communications Manager Express - version 7.1.
I would like to use VXML Sample scripts on 3 FXO ports , so when an incoming call occurs it will ask to which internal phone number should it redirect the caller to.
My problem is that it does not seem to be working,
when i turn on the service on the dial-peer voice # pots the phone does not ring anymore.
It only rings when the service is turned off.
This is where i have got the script samples and configuration from:
https://www.cisco.com/c/en/us/td/docs/routers/access/xml/voice/quick/guide/vxml_qsg.html#wp40983
Once again, the idea is:
When an incoming call occurs on port 1 of 3 voice gateways /FXO voice port/ the caller will be asked to enter a number which will represent a different Cisco 7912 phone.
Please, excuse me if i have not explained myself very well.
I will be glad if you could help me with that task.
Thank you in advance
yawming
I think 2811 might not be supported anymore.
