Which Cisco IoT Gateway?
ganeshpisal
Community Member
I have requirement for Cisco IoT Gateway:
1.       Should be able to connect 2 to 3 PLC/PAC to one IoT Gateway.
2.       Should be able to connect multiple (4 to 5) sensors – Weight Sensor, Motion Sensor, Temperature etc.
3.       Should be able to connect multiple (4 to 5) output devices – LED Display, Siren etc.
4.       Wanted to connect few sensors to Gateway using Bluetooth and Wi-Fi
5.       Should be able to connect one mobile device
6.       Gateway should have local storage. We want to store around 500 MB data on Gateway
7.       Local Analytics and decision on IoT Gateway. We want to develop code on Gateway for local decision making by Gateway based on sensors input value.
8.       USB support required
9.       Multiple Serial ports are required
Please suggest me good Cisco IoT Gateway. I want to purchase it in India.
Geevarghese Cheria
Hi Ganesh,
   Request to post your question under IR910 community which could help more experts related to IOx to see your question.
For related info please refer - Cisco IR 910 Series FAQ - Cisco
Thanks and Regards,
Geevarghese
