Steve Zhang
IR829 router is similar to CGR routers. And IR809 is same as IR829.
IR829 has one GE0 wan interface which needs an Ethernet SFP for connecting the WAN Ethernet cable in our LAB switch, four LAN switch ports and 2 serial interfaces.
Access the console of IR829:
IR829 is using a mini-USB port for the serial interface. Please use a Mini-USB cable to connect to your PC. You may need to install the driver for the console. Here is the link for the drive. The default baud rate is 9600. For details, please refer to Cisco IR829 Industrial Integrated Services Router Hardware Installation Guide - Connecting the Router [Cisco 800 Series ….
Bundle image installation on the 829:
bundle image can be used to upgrade the 829 - ir800-universalk9-bundle.SPA.156-1.T1.bin -- which has IOS, guset OS , Hypervisor from ir800-universalk9-bundle.SPA.156-1.T1.bin. You need to download the bundle image from CCO and uploaded it for IR829 flash by SCP, HTTP, TFTP, etc. For example:
copy scp://username@10.10.10.10//home/username/ir800-universalk9-bundle.SPA.156-1.T1.bin flash:
bundle install flash:ir800-universalk9-bundle.SPA.156-1.T1.bin
The image can be upgraded using the 829 bundle image available here Cisco Systems CCO. You can upgrade the images individually also.
Please notify, the 15.6 or later can be upgraded from 15.5.3 only. All the other version such as 15.5.2 or earlier must be upgrated to 15.5.3 first, and then upgraded to 15.6 or later.
IR829 Configuration:
  • Step1: Configure the wan interface of the 829 router GE0.
Set the GE interface with the specific IP address and network mask.
"ip nat outside" to specify that the interface is connected to the outside network. If your GOS is assigned with a publish IP address, you don’t need to set the NAT related in all the configurations below.
interface GigabitEthernet0
ip address 72.163.206.123 255.255.255.0
ip nat outside
ip virtual-reassembly in
[NOTE]: Here GLC-T SFP for GE0 is supported. The OS version on which it is officially supported is 15.5(3)M0a or above. And you need to add the below CLI.
config terminal
service internal
service unsupported-transceiver
And you may also use the GE interfaces (GE1-4) instead of WAN interface to access internet. Here we use GE1 and Vlan999 as an example.
interface GigabitEthernet1
switchport access vlan 999
no ip address
interface Vlan999
ip address 10.75.189.144 255.255.255.0
ip nat outside
  • Step2: Configure the "ip route" and "ip default gateway"
ip default-gateway 72.163.206.1                              //or 10.75.189.1 if you are using GE1 as example
ip router 0.0.0.0 0.0.0.0 72.163.206.1                      //or 10.75.189.1 if you are using GE1 as example
  • Step 3: Configure the GOS and IOS connectivity interface - GE5
ip nat inside  -  Enter ip nat inside to specify that the interface is connected to the inside network and
ipv6 enable   -  IPv6 must be enabled also have to configured
interface GigabitEthernet5
ip nat inside
duplex auto
speed auto
ipv6 enable
  • Step 4: To assign an IP address to the Guest OS, configure a Local DHCP pool:
ip dhcp excluded-address 192.168.1.1 192.168.1.5
ip dhcp pool gospool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1                                 <<<<<<<<<<<<<<<,GE5 is the gateway to GOS
dns-server 64.104.123.144
  • Step 5: Nat configurations:
ip nat inside source list NAT_ACL interface GigabitEthernet0 overload
ip nat inside source static tcp 192.168.1.6 22 interface GigabitEthernet0 2222
ip nat inside source static tcp 192.168.1.6 8443 interface GigabitEthernet0 8443
ip access-list standard NAT_ACL
permit 192.168.0.0 0.0.255.255
[NOTE]: Please replace the GigabitEthernet0 with Vlan999 in case the GE1-4 is used for connecting internet.
ip nat inside source list NAT_ACL interface Vlan999 overload
ip nat inside source static tcp 192.168.1.6 22 interface Vlan999 2222
ip nat inside source static tcp 192.168.1.6 8443 interface Vlan999 8443
Make sure 8443 is enabled for further deployment of applications. Verifying GOS is running and got the IP address from the DHCP pool with “show iox host list detail”.
And you should have “privilege 15” to access the Web interface (such as IOx Local Manager) for IR829. The IOS command is: username yourusername privilege 15 password 0 yourpassword
Verifying GOS is running and get the IP address from the DHCP pool:
IR800#show iox host list detail
IOX Server is running. Process ID: 261
Count of hosts registered: 1
Host registered:
    IOX Server Address: FE80::86B8:2FF:FE9C:ED8C; Port: 22222
    Link Local Address of Host: FE80::1FF:FE90:8B05
    IPV4 Address of Host:       192.168.1.6                                      <<<<<<<<<<<<<<<<<<<<<<ip address got from the DHCP Pool.
    IPV6 Address of Host:       fe80::1ff:fe90:8b05
    Client Version:             0.1
    Session ID:                 1
    OS Nodename:                IR800-GOS-1
    Host Hardware Vendor:       Cisco Systems, Inc.
    Host Hardware Version:      1.0
    Host Card Type:             not implemented
    Host OS Version:            1.28
    OS status:                  RUNNING
    Interface Hardware Vendor:  None
    Interface Hardware Version: None
    Interface Card Type:        None
    Applications Registered:
        Count of applications registered by this host: 0                        <<<<<<<<<<<<<<<<<<<<<<<< applications running on the GOS
IR800#
Starting Guset OS :
IR800#guest-os 1 start
Stopping GOS:
IR800#guest-os 1 stop
Upgrade of guest OS:
Copy Guest OS image to IOS flash partition
guest-os 1 stop
guest-­os 1 image uninstall
guest-os 1 image install flash:<GOS image in falsh> verify
guset-os 1 start
If you want to install the original Guest OS from the bundle image, you may run the below command:
bundle install flash:<bundle image in falsh> exclude HV-IOS
All the cartridges and applications for IOx are stored in the specific partition in IR829, and will not be impacted by the upgrade of Guest OS. If you have installed the cartridges and applications for the old Guest OS, all the cartridges and applications will be still there after the upgrade with the new Guest OS. (Please notify: for some early versions, due to the modification of CAF framework, there is some impact for the applications. You'd better remove all the cartridges and applications before upgrade of Guest OS to avoid the incompatibility, and then re-install them accordingly after upgrade.)
FOR THE LATEST INFORMATION AND CONFIGURATION, PLEASE REFER TO https://developer.cisco.com/docs/iox/#ir-800-series
evo
Hi Jun,
Thanks for your response.
Do you have a list of sensors integrated already in IR829?
Thanks!
Edgar
junxu2
Hi Edgar,
Because IOx is based on Yocto Linux and customer can integrate their drivers on this platform, sensor drivers is not default integrated in IR829 and we don't have a list of recommended sensors. But, when you plug USB to IR829, you can see a "ttyUSBx" device which can be utilized by your driver. That just like to insert a device to a linux device. Many linux drivers with x86 64bit arch can be used in IOx.
Jun
rbaindou
I received an IR829 for a project.
My current setup is that I have a cable modem and netgear nighthawk for wifi and wired nodes.
I purchased this GLC-T compatible SFP to copper adapter for the WAN/GE0 port.
amazon.com/gp/product/B01CU2ZGVI
But the light is not turning on when I plug it into my netgear router.
But when I plug in GE1 into the netgear, I acquire an IP address for the IR829 itself, and the GE2-4 seemed to act like a switch, effectively adding all the nodes wired to the 829 onto the DHCP network advertised from the netgear.
My original goal was to set the DHCP pool to 192.168.2.0/24 for GE1-4 and receive an IP address via DHCP also on WAN/GE0 from the 192.168.1.0/24 block.
So a couple of questions.
Should I exchange the adapter? I added the `no shutdown` command to the interface GigabitEthernet0 configuration. So it should be up, I am assuming.
And is what I am trying to do even possible?
And if so how to execute this idea off of GE1 if my copper adapter is bad?
Thanks in Advance
Here is some of my show run output:
http://pastebin.com/avyY3YLZ
And sorry if my networking theory is all off, I took CCNA over a decade ago, and then became a web developer.
Steve Zhang
Hi Robert,
The dhcp pool speedway (192.168.2.x) you set is for GOS on IR829 IOx, not for the GE0-4. For GE0, it is the WAN port (SFP), and GE1-4 are GE LAN port(RJ45). The GE0 and GE1-4(with switchport) IP addresses depends on what external port they connect. For details, you may refer to Cisco IR829 Industrial Integrated Services Router Hardware Installation Guide - Product Overview [Cisco 800 Series Indus…. Hope it helps.
Steve
fcolumbu
Hi Robert,
This link will help you with to explain the configuration of the platform:
https://developer.cisco.com/media/iox-dev-guide-11-28-16/platforms/platform-ir8xx/
This link will help you regarding the SFP:
Unsupported GBIC (SFP) in sub-module of Catalyst 3850 Switch – Mitigation Techniques - Cisco
Hope this works for you.
Frank
rbaindou
I am still full of questions:
For Example, here is one confusing thing:
I think am supposed to install version 15.6(1)T1 because when I do show run I it says version 15.5
But when I do show platform guest-os it says 1.28.
That's is very confusing. So I am supposed to copy the ioxvm image for 15.6 and install it on to guest-os and its supposed to read version 1.29?
Also I am unable to access the Local Manager. What is the default username and password?
None of the commands to update credentials work.
I get output like this when I try to put the username and password according to the document
IR800>enable
IR800#config t
Enter configuration commands, one per line.  End with CNTL/Z.
IR800(config)#username admin privilege 15 secret admin
IR800(config)#end
IR800#show run | sec username
username admin privilege 15 secret 5 $1$YzuF$jVTZzgDuEjIyyxMGU2NoT.
IR800#
But then I still can't access the Web UI.
Then my question was not really answered, is my SFP to GBE adapter bad if the light doesn't turn on?
Did I miss some command to actually power up GE0?
-Robert Baindourov
fcolumbu
Hi Robert,
If you observed that "when I do show run I it says version 15.5," it means that you will need to do a bundle install to the latest software.
IOx will not run using 15.5.
Please follow the guide here:
https://developer.cisco.com/media/iox-dev-guide-11-28-16/platforms/platform-ir8xx/#upgrade-using-bundle
Please use the latest image from cisco.com.
https://software.cisco.com/download/release.html?mdfid=286287074&softwareid=280805680&release=15.6.3M1&relind=AVAILABLE&rellifecycle=ED&reltype=latest
Frank
junxu2
Based on meeting with you, hope you have solved the problem. Basically, the initial configuration is need to be done for network on IOS side.
rbaindou
Thank you Jun, you were a great help.
I am very humbled by all the commands that are needed to setup the router.
I have so many questions still, like why the loopback interface needed to be 1.1.1.1.
IOS vs IOX
Why dual operating systems, and do I only need to upgrade the guest os and not the... I guess firmware?
Or I guess the firmware lives even lower, under the hypervisor?
Will the configuration you entered survive the ioxvm upgrade?
Unfortunately I started recording our webex a little late, and still don't have the confidence that I would like about how to set these industrial routers up correctly.
So Now I am trying to search the cisco learning network to try and find a way to fill my knowledge gap.
Reading a command reference is only going to show me how to use the commands correctly and I won't understand why you did the steps you did.
Can someone recommend a course on the cisco learning network for me?
Thanks in Advance.
junxu2
Hi Robert,
"1.1.1.1" is for easy access to IOS. You can ignore that. That won't impact any function.
For more detail information about IOx, please refer to https://developer.cisco.com/site/iox/
Jun
anirukas
Hi All,
I have followed the procedure provided for initial set up. The output of the command "show iox host list" gives me the below result:
  No host is registered.
Please help in resolving this.
a.veneziano
Hi All,
today i've try to modify root password on GOS but I've received this error:
ir829#iox host exec "resetpw cisco" sw1-GOS-1
  Error: operation failed (at IOX Client): Script not found
ir829# Cisco IOS Software, ir800 Software (ir800-UNIVERSALK9-M), Version 15.7(3)M, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
ir829# show platform guest-os
Guest OS status:
Installation: Cisco-GOS,version-1.4.2.3
State: RUNNING
Could you help me?
Thanks in advance
Steve Zhang
Please note, the latest versions of IOx use the “username _______ password ______” configured in IOS for access to IOx. It is not recommended to use "resetpw" any more.
a.veneziano
Thank you very much Steve.
I found that command in the last IR829 configuration guide (Updated May 18, 2017) in the section related to Guest OS.
hengchang zhao
I got a IR829 router from a project and i want to setup IOx on the router.  i have followed the procedure provided for initial setup  But now i got this information. And i can not login on the GOS.  If someone can help me to troubleshooting on it.
IR800#telnet 192.168.1.1 2070
qemux86-64 login: root
IOS user password:
Login incorrect
GOS already got an IP address from internal DHCP server.
IR800#show ip dhcp  pool
Pool gospool :
Utilization mark (high/low)    : 100 / 0
Subnet size (first/next)       : 0 / 0
Total addresses                : 254
Leased addresses               : 1
Pending event                  : none
1 subnet is currently in the pool :
Current index        IP address range                    Leased addresses
192.168.1.12         192.168.1.1      - 192.168.1.254     1
IR800#
IR800#ping 192.168.1.11
Sending 5, 100-byte ICMP Echos to 192.168.1.11, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
IR800#
Below is our configuration file.
hostname IR800
boot-start-marker
boot-end-marker
enable password cisco123
aaa new-model
service-module wlan-ap 0 bootimage autonomous
ignition off-timer 900
ignition undervoltage threshold 9
no ignition enable
ip domain name cisco.com
ip cef
ipv6 unicast-routing
ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid IR829GW-LTE-LA-QK9 sn FGL21132601
username cisco123 privilege 15 password 0 cisco123
username root privilege 15 password 0 cisco123
username test password 0 test
redundancy
ip address 10.199.92.48 255.255.255.192
ip nat outside
ip nat inside
duplex auto
speed auto
ipv6 enable
ip nat inside source static tcp 192.168.1.9 22 interface GigabitEthernet0 2222
ip nat inside source static tcp 192.168.1.9 8443 interface GigabitEthernet0 8443
ip route 0.0.0.0 0.0.0.0 10.199.92.1
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ipv6 ioam timestamp
control-plane
line 1/4
transport preferred none
transport input all
transport output none
stopbits 1
