ACI and Kubernetes sandbox not configuring Aplication EPG
Amit Singh
Hi All,
I used the above sandbox and it says that ACI is configured while initalization by using acc-provision python tool and I am suppose to see the EPG when I login first but it is not happening.
Can anyone suggest if you are seeing the same issue. Devnet support can you help me fix this issue.
Amit
zowu
Hi Amit,
We've added you into sbx23 role group and you can access Tenant's application profile.
