apicdc changed web site
zbig.lupina
Visitor
hi,
there is a site
https://sandboxapicdc.cisco.com/
which should be accessible for user admin/ciscopsdt.
It does not work now. Where is the API for APIC (Infrastrucure Controller) now ?
8 Replies 8
zbig.lupina
Visitor
again credentials changed to
admin/!v3G@!4@Y
forget.
Sandbox https://devnetsandbox.cisco.com/RM/Diagram/Index/18a514e8-21d4-4c29-96b2-e3c16b1ee62e?diagramType=Topology
Connecting to the ACI Server:
This ACI Sandbox Lab contains a shared ACI Server Instance.
The server can be connected using login credentials admin and password : !v3G@!4@Y and is located at
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
today it does not work. Everyday a change, everyday something different. So cisco wants to discourage us or leverage difficulty ?
@zbig.lupina with this being an open sandbox (always-on) they can be subject to misused and abuse, which often prevents others from using them. If you see an issue with the sandbox you can create a ticket with the ENG Support Here who will advise further.
Please create this ticket here Sandbox Ticket Support
Hope this helps!
I did so (repeated 3 times) and ... support does not work .. too.
rc01
Community Member
I can confirm that these credentials work (in regards to the Parson JSON lab! (relevant to the get-tenant-json.py) file).
As mentioned above, all you have to do is change the password to !v3G@!4@Y
zowu
The APIC appliance is now recovered.
again all exactly the same. Service dead and even support ticket cannot be created. I give up.
