AppD Lab not able to login
Tania S
I can login on the VPN, and not able to reach the VMs.
Ruben Cocheno
@Tania S
Check your LAN settings, and make suere you don't have the same subnet as the VMs. If not the case, reboot the VMs and check the services.
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Ruben Cocheno
@Tania S
