AppDynamics monitoring is not working
1pgordo
I can't see the monitoring working properly, any steps on the guides missing?
Ruben Cocheno
@1pgordo
if you follow the lab as-is you should be able to get exactly what is there unless there an underlying problem
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Ruben Cocheno
@1pgordo
