Cisco ACI always on sandbox GUI is not able to access using admin
eahmed.ext
Hi All ,
Is anyone facing issue to connect Cisco ACI always on sandbox using GUI . Default username : admin , password : !v3G@!4@Y is not working for URL : https://sandboxapicdc.cisco.com/  .  it is always asking for current password and new password pop-up window .
However, same credential is using postman or other Automation tools .
It would be highly appreciated if you face this kind of problem and share your inputs to fix the issue .
with regards
Erfan
Hi @bigevilbeard  ,
Thanks for your findings and help.
Now it is working in incognito mode for me as well.
6 Replies 6
Getting a 404 on that URL, looks to be an issue, would check back in a few days.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hi @bigevilbeard ,
Thanks for your reply.
It would be highly appreciated if you check and let me know your findings to access APIC always on GUI portal.
I am able to login Sat 9th Dec 2023 16:03:12 GMT using Chrome Version 120.0.6099.71 (incognito window) and details `admin/!v3G@!4@Y` - it is slow to load, but once in i am able to navigate around the UI.
Hi @bigevilbeard  ,
David McFarland
I've just tried to access the ACI always on in both normal and incognito mode and get a 404
I first enabled the access for 8 hours, received an email that my session was ready (This is the always on, not the on-demand). But, nada
Hi @David McFarland i was able to login to the always on version this morning (10:20:40 GMT) via Chrome incognito using the same details above and in the sandbox information section.
Hope this helps.
