Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco VIRL and Industrial Switch IES network redundancy HSR PRP
pabwork
Trying to use the Multi-IOS Cisco Test Network Lab  I could not find  a way to simulate IE4000 switches network redundancy feature.
I'd like to simulate an HSR ring or a PRP star/ring topology.
Is it ever possible ?
Thanks and Regards.
You should be able to create your own networks as long as the device image is there, maybe try this in the new CML Sandbox ?
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hello, thanks for the suggestion, I just tried it but it also does not brings features from cisco IES4000 switches.
all the switch we can install from the lab ignore the hsr-ring interface command.
