Collaboration lab issue
alain.florencie
Community Member
I re-started a collaboration 10.5 lab for the whole week (i couldn't extend on friday the lab i had last week time limit exceeded too bad)
Last week i was on rave09 and changing the VPN connection with FREEABCGROUP9  worked straightfully.
I modified the cisco router VPN settings according to the new lab setting on rave13 (we using external cisco voip phones)
VPN is not coming up...using FREEABCGROUP13..
as a test i tried another group and i was able to get the VPN up using FREEABCGROUP8  (weird...)
but i can't reach any machines..
what's wrong?
Alain
That's good.
We are fixing the issue with RAVE13 and will release it back into the pool when it is tested.
Thanks for your patients Alain.
Can you mark this thread as answered.
Joe
9 Replies 9
jokearns1
Hi Alain,
I am checking on this issue now.
Can you confirm that the tunnel is built (getting QM_IDLE), but you cannot ping the machines?
from the router "ping 10.10.20.1 source vlan1"
Joe
sh cry isa
64.103.37.21    xxx.xxx.xxx.xxx     QM_IDLE           2952 ACTIVE  (with GROUP8)
#ping 10.10.20.1 source vlan1
Sending 5, 100-byte ICMP Echos to 10.10.20.1, timeout is 2 seconds:
Packet sent with a source address of 192.168.100.1
Success rate is 0 percent (0/5)
That ok. I can see it connects to group8 but there are no servers on that vlan for you as it was not selected.
This problem seems to be isolated to vlan13 with IPsec. I am troubleshooting now.
In the mean time, cancel your current reservation. we rebook on another vlan.
Don't rebook until I let you know.
Joe
Hi Alain,
I have found the issue with that VLAN and it is being corrected.
Can you rebook again?
Joe
Hi Alain,
Found the issue and it is being corrected.
Joe
I just restarted a new lab ..
i'm waiting until it's up  and i will get back to you.
Alain
Collaboration lab is up on rave04 i used FREEABCGROUP14
VPN is up
i can reach the CUCM server..
Alain
That's good.
We will extend your reservation for the time you lost.
Thanks for your patients.
Can you mark this thread as answered?
Joe
That's good.
Joe
