Showing results forĀ
Search instead forĀ
Did you mean:Ā
Connectivity Issues and VPN
anwar78alam
Frequent Visitor
Frequent Visitor
Hello Team,
I'm unable to log into the Cisco AnyConnect Application for VPN connection. When I enter the given VPN Address "devnetsandbox-usw1-reservation.cisco.com:20277" with given user name and password, it pop up login Failed, no error message. Is this normal behavior or should I wait for more time. This is the first time I am trying to access lab environment. current status of lab showing active.
Any assistance on this will be very helpful
17 Replies 17
I just connected to you reservation using the credentials assigned and I could connect ok
devnetsandbox-usw1-reservation.cisco.com:20356
Thank you. Seems my office has your servers blocked on the f/w. I'm in now
CSCO11744899
Frequent Visitor
Frequent Visitor
Thanks it works your way
