could not login to UCS manager sandbox using UCS Python SDK
a11024
[1] I was able to SSH to 10.10.20.110 and 10.10.20.113 (the 2 UCS manager sandbox IP addresses) via Cisco AnyConnect.
[2] But the following python script does not work.
from ucsmsdk.ucshandle import UcsHandle
HANDLE = UcsHandle("10.10.20.110", "ucspe", "ucspe") or
HANDLE = UcsHandle("10.10.20.110", "admin", "ciscopsdt")
# Login into Cisco UCS Manager
HANDLE.login()
 the error message is
 Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "C:\Users\david.smith\AppData\Local\Programs\Python\Python39\lib\site-packages\ucsmsdk\ucshandle.py", line 135, in login
return self._login(auto_refresh, force, timeout=timeout)
File "C:\Users\david.smith\AppData\Local\Programs\Python\Python39\lib\site-packages\ucsmsdk\ucssession.py", line 599, in _login
response = self.post_elem(elem, timeout=timeout)
File "C:\Users\david.smith\AppData\Local\Programs\Python\Python39\lib\site-packages\ucsmsdk\ucssession.py", line 318, in post_elem
response = xc.from_xml_str(response_str, self)
File "C:\Users\david.smith\AppData\Local\Programs\Python\Python39\lib\site-packages\ucsmsdk\ucsxmlcodec.py", line 98, in from_xml_str
response.from_xml(root_elem, handle)
File "C:\Users\david.smith\AppData\Local\Programs\Python\Python39\lib\site-packages\ucsmsdk\ucsmethod.py", line 143, in from_xml
child_elems = elem.getchildren()
AttributeError: 'xml.etree.ElementTree.Element' object has no attribute 'getchildren'
Anyone knows why?
thanks
Patrick
Thanks @bigevilbeard:
 I uninstalled Python 3.9.4 and installed 3.7.3 and the same script worked on 3.7.3
 You can close the case. Thanks for help.
Sincerely,
Patrick
Hello, this isn't a fault with the sandbox, this looks like the version of python you are using is not supported (Python 3.9 incompatibilities). I would suggest, trying this with another Python (3.4 is listed as working) version or creating an issue on the repo https://github.com/CiscoUcs/ucsm_apis - I see there is further support via a slack room, details are here https://pypi.org/project/ucsmsdk/
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Sincerely,
Patrick
