DevNet Always on Sandbox - Permissions issue
hoylandpaul
I'm trying to add a device to the always on SandBox for DevNet but getting a 403 response back:-
    "message""Role does not have valid permissions to access the API"
Any ideas?
thanks
Paul
5 Replies 5
You don't say which sandbox you are using, so taking a guess this is the DNAC one. This maybe the same issue - https://community.cisco.com/t5/networking-blogs/authenticating-rest-api-calls-to-dnac-getting-started/bc-p/3678811/highlight/true#M365
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Yes it is the DNAC sandbox that I'm using. A post to get a token works and a GET on /network-device works but when I try a POST on /network-device to add a device I get that 403 response.
thanks
Paul
Thanks - it could be that our always-on DNAC sandbox are mostly read-only. You might wish to reserve a DNAC sandbox which will give you full admin rights and privileges.
Ah, OK, that makes sense.
Is there only 1 DNAC sandbox that it is possible to reserve? Lab numbers 2 and 3 keep saying "Cannot be found"?
thanks
Paul
There should be three to reserve unless there are issues or they have been taken out for planned work etc..
