Devnet: sandbox connectivity Issues and VPN
sercopi
Level 2
Level 2
I configured CSR1000v inside the SandBox, and now I would like to route streaming telemetry into the VPN to my PC is possible?
Best Regards
Giovanni Davide Saccà
It might be easier to use the Model Driven Telemetry sandbox, you might run into issues with ports being blocked running this traffic over the VPN.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hope this helps.
thank you for your reply, should you send me the ports may be blocked over the VPN? And in details at which side of the VPN may be blocked? At Cisco side, or at my PC side?  What I know is that necessary at least port 57000 from the device to the receiver.
And from the receiver to the network device for NETCONF reason, 830/tcp.
I know that there's a DevBox machine dedicated inside the SandBox, but on my PC I'm more familiar, and also I'm already installed everything is need to act as a receiver.
I hope may you help me; if will be useful, I will share any technical details with the community.
Best Regards
Giovanni Davide Sacca'
I cannot provide that detail, firstly i do not have it. Second, i do not believe it is published due to security posture. It would be a case of testing this to see if this works.
Sorry i could not help further with your question,.
