DevNet Sandbox missing reservation for Multi-IOS pre-configured
VincentVlk82
Frequent Visitor
Frequent Visitor
Hi all,
is there any change in DevNet Sandbox reservations for Multi-IOS pre-configured Topologies? I don't see them in the Lab Catalog. Yesterday it was working fine.
Timezone: CEST UTC +2
Thanks in advance & Best regards, Vincent Vlk
P.S. I can use CML Lab but it has only 2 Hours runtime, which is not practical for my studies.
2 Accepted Solutions
VincentVlk82
Frequent Visitor
Frequent Visitor
Edit:
Managed to investigate more and I see there is an option in CML Enterprise, to change the reservation Time-Limit, which is cool 🙂😀
P.S. But I still miss the full-mesh "9 Router Mesh" Multi-vIOS topology, which is already preconfigured and with some fantasy, it can by modified to many topology variations. 😄😅
@VincentVlk82 you can import the virl files to CML - the one you are looking for is here --> https://github.com/virlfiles/9_router_mesh
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
VincentVlk82
Frequent Visitor
Frequent Visitor
Edit:
Hope this helps.
this is fantastic! Thank you very much for your help. I'am just exploring the DevNet functionality, so this is very helpful.
Kind regards, Vincent
