DevNet sandbox not able to connect with provided credentials to DevNet box
weigang
Tried DevNet lab:
Power On Auto Provisioning (POAP) on Nexus Switches Part 1 - Setting up POAP Infrastructure
Reserved the sandbox. Followed the instruction setting up the VPN. Unfortunately, not able to proceed since ssh to 10.10.20.20 failed authentication, using the provided credentials from this site:
https://devnetsandbox.cisco.com/RM/Diagram/Index/2c274c7d-65ed-4f44-9ff1-d00776cd13e0
Please update the credentials.
5 Replies 5
eublack
I was able to duplicate the issue. Working on a resolution. Will update once corrected.
Thank you
eublack
Issue has now been corrected. Please retry with a new reservation using default credentials as per instructions pane.
Thank you
weigang
Thank you for the update.
I am able to connect to 10.10.20.20 as root. However, it failed at the first step of running ansible playbook to populate dhcp config file:
(python2) [root@localhost poap]# ansible-playbook devbox_dhcp_setup.yml
PLAY [devbox] ******************************************************************
TASK [setup] *******************************************************************
fatal: [10.10.20.20]: UNREACHABLE! => {"changed": false, "msg": "Failed to connect to the host via ssh: Permission denied (publickey,gssapi-keyex,gssapi-with-mic,password).\r\n", "unreachable": true}
       to retry, use: --limit @/root/sbx_nxos/learning_labs/poap/devbox_dhcp_setup.retry
Any tips?
output of ansible playbook -vvv
(python2) [root@localhost poap]# ansible-playbook devbox_dhcp_setup.yml -vvv
Using /root/sbx_nxos/learning_labs/poap/ansible.cfg as config file
statically included: /root/sbx_nxos/learning_labs/poap/dhcp_server/tasks/apparmor-fix.yml
PLAYBOOK: devbox_dhcp_setup.yml ************************************************
1 plays in devbox_dhcp_setup.yml
Using module file /root/sbx_nxos/venv/python2/lib/python2.7/site-packages/ansible/modules/core/system/setup.py
<10.10.20.20> ESTABLISH SSH CONNECTION FOR USER: None
<10.10.20.20> SSH: EXEC ssh -C -o ControlMaster=auto -o ControlPersist=60s -o StrictHostKeyChecking=no -o KbdInteractiveAuthentication=no -o PreferredAuthentications=gssapi-with-mic,gssapi-keyex,hostbased,publickey -o PasswordAuthentication=no -o ConnectTimeout=10 -o ControlPath=/root/.ansible/cp/ansible-ssh-%h-%p-%r 10.10.20.20 '/bin/sh -c '"'"'( umask 77 && mkdir -p "` echo ~/.ansible/tmp/ansible-tmp-1534269542.35-179966824760945 `" && echo ansible-tmp-1534269542.35-179966824760945="` echo ~/.ansible/tmp/ansible-tmp-1534269542.35-179966824760945 `" ) && sleep 0'"'"''
    "changed": false,
    "unreachable": true
PLAY RECAP *********************************************************************
10.10.20.20                : ok=0    changed=0    unreachable=1    failed=0
I resolved the connection issue after generating rsa keys. Please confirm this is the right way to do.
