DNA Center with ISE Lab 3, DNAC not responding
rl7529
I am connected to the lab successfully and able to connect to the ISE GUI as well as the Cisco Modeling Labs console, however I am not able to connect to the DNAC server at all.  When I attempt to connect using both HTTP/HTTPS, I see no bytes or frames being received on the AnyConnect client.  It appears that the server is down or unresponsive.  Is there any way to restart that service or do I need to reserve another lab and hope it works there?
Alexander Stevenson
Hi @rl7529,
I would try and see if anyone else had a similar issue:
https://community.cisco.com/t5/custom/page/page-id/search?filter=location:4426j-disc-dev-devnet-sandbox&q=DNA%20Center%20with%20ISE%20Lab&mode=board
If it seems like a one-off issue, you can terminate the sandbox and reserve another lab.
Hope this helps
I saw this the other day also https://community.cisco.com/t5/devnet-sandbox/sandbox-devices-not-available/m-p/4919156#M8594
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
rhoover00
DNAC not responding is still an issue.  I just started my lab and the DNAC is showing offline.
Roger Moore Jr
The DNA Center GUI is still offline.  Any idea when this application will be working?  I reserved the lab to test the DNA Center APIs.
