Endpoint IVT. Sound from endpoints in local cluster
johan.andren
Hi I'm running a IVT end user lab and it says that I should be able to both here the sound from the remote server on a specific extension and that if I use commands like Play:AreYouThere.raw you should be able to here that in the A-part...
I can't get any of this to work.
// Johan
0 Replies 0
