Error - Cisco AnyConnect - IE3400 - Edge Compute and Cyber Vision
msk84
Currently, I have a problem when logging via Cisco AnyConnect to the sandbox reservation I made for "IE3400 - Edge Compute and Cyber Vision".
The message I get is:
"VPN establishment capability for a remote user is disabled. A VPN connection will not be established"
My reservation is: devnetsandbox-usw1-reservation.cisco.com:21418
My username is: msk84
I thought it's a provisioning error so I have cancelled my reserwation and order it again but I'm getting same problem?
Maybe remote users are disabled for this lab?
It sounds like you are using a jump host or from virtual machine to connect to the sandbox? If this the case, i do not think this will work, there was a number of threads on this and articles saying you could update the local any connect file, but i have never seen this be a success in this case.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
