Everytime Facing Same Error
mehwish0093
9 Replies 9
Is see this one at capacity right now, looks like the same issue you reported before. Guessing there might be an issue with reservations and the engineering team will need to check and advise.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Sir, this is not a reservation issue. I reserved this lab for four days, but when the lab started, I got an error saying “Launching environment failed.” The main issue is that the environment could not be launched successfully.
@mehwish0093 when did you start the reservation?
Secure Equipment Access - IoT Operations Dashboard  I reserve for 4 days but after lunching showing Error "Please note
Torque was not able to complete launching your environment.
For more details, contact your space admin"
angelo556
Community Member
Hey mehwish0093! It looks like your post didn’t include the actual error message — could you share what the error says or maybe upload a screenshot that shows it clearly? Without knowing what the message is, it’s hard to tell whether it’s a sandbox setup issue, a permission problem, or something else. Once you drop the exact error, I can help you figure out what’s causing it and how to fix it quickly.
see this screenshoot you can see Torque was not able to complete launching your environmemt
@mehwish0093 is now working or you face the same issues?
amirzkria2
Community Member
facing same issue since last week
amirzkria2
Community Member
I tried using private browser and it works
