Firepower Management Center sandbox credentials not working
edward_uc
Reserved FMC sandbox. I got the credentials emailed to me, but it is not working.
Did I miss anything? I've been using this in the past (when it was on the old portal) and never had issues.
TIA,
Ed
7 Replies 7
Ben Ss
I tried to launch another FMC instance, but the credentials doesn't work.
Thanks @Ben Ss. Good to know it's not just me .
We will take a look.
Joe
Hi @edward_uc & @Ben Ss
Unfortunately the scripting that add the password has hit errors all of sudden. Reason unknown yet but we are troubleshooting.
I will come back to you tomorrow.
Apologies for the inconvenience,
Joe
Thank you
Hi @Ben Ss ,
Can you try this again? Occasionally, FMC is encountering a password character it does not like. I have tried a number of times now and can successfully login.
Joe
I try it today. it's good now. Thanks a lot.
