Having issue to connect Sandbox
akshayvaiti
Hello Team,
I am unable to login into the VPN devnetsandbox-emea-gwy.cisco.com:20219
This is for Identity Services Engine with MUD LAB on Sandbox
getting error connection attempt has timed out please help
Check to see if the ports are blocked from your SRC. The port range will be anywhere from TCP 20100 through TCP 20354. Give that a try and you should be good to go. If that's not working, keep in mind VPNs also use TLS (TCP 443) and DTLS (UDP 443). Though typically these are open in most organizations.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Thanks for the input
Actually I am using Sandbox from my home only
Try and tether your cell phone (or via another ISP) and see if you can connect then.
Hope this helps.
