ios-xe-mgmt.cisco.com lab erorr
yangcharlie
Hello, All,
I have been working on a couple of Devnet Lab, and found not request responses from ios-xe-mgmt.cisco.com
in all the labs neither Postman nor Python requests.
Below is an example when I am working on "Exploring IOS XE YANG Data Models with RESTCONF"
1, I was able to open Sandbox, but no any elements showed in SanDbox ENVIRONMENT
the IOS XE on CSR Recommended Code Always-On Sandbox
2, updated environment on Postman with new parameters and no response from sandbox,
please see attached pics.
20 Replies 20
I'm pressing try it now and press on command or structure, but nothing is editable for me
I can ssh to the device fine.
(venv) $ ssh developer@ios-xe-mgmt.cisco.com -p 8181
Nicolas Cage is the
Tiger King
Password:
Password:
Welcome to the DevNet Sandbox for CSR1000v and IOS XE
The following programmability features are already enabled:
  - NETCONF
  - RESTCONF
Thanks for stopping by.
csr1000v#
I am using information from the sandbox instruction page https://devnetsandbox.cisco.com/RM/Diagram/Index/27d9747a-db48-4565-8d44-df318fce37ad?diagramType=Topology
CR1000V Host: ios-xe-mgmt.cisco.com
SSH Port: 8181
Username: developer
Password: C1sco12345
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Can I ask you to share a screenshot.
For me I checked your link and I'm getting the same as I shared in the previous screenshot I attached earlier.
Clicking on the tile in the sandbox will yield no results. To access the sandbox an ssh client is required to connect to the device. Using Mac/Linux directly use the OS native SSH client, or Window using an SSH client such as PuTTY.
Hope this helps.
mike13d98
The link below is part of DevNet training section 2 on APIs. [REST APIs Part 1: HTTP is for more than Web Browsing ]
When I click the link below to go to the Sandbox, I also get an error [ Sandbox Lab not found ] .
Is this a temporary error, or is there a new link and the one below needs updating, or something else ?
Hey there try these links - the reason it might not be found is the device/tile might be temporary our for work. Please try these links
Hope this helps.
