Issue with editing configurations using IOS XE on Cat8kV Sandbox
GJG
I am executing https://github.com/CiscoDevNet/BRKDEV-1368/blob/master/netconf/example4.py on the Always On sandbox
I have amended the following
(1) device_info.py
ios_xe1 = {
"address": "devnetsandboxiosxe.cisco.com",
"port": 830,
"username": "admin",
"password": "C1sco12345"
(2) config-temp-ietf-interfaces.xml
<config xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
       <interfaces xmlns="urn:ietf:params:xml:ns:yang:ietf-interfaces">
          <interface>
                 <name>{int_name}</name>
                 <description>{int_desc}</description>
                 <type xmlns:ianaift="urn:ietf:params:xml:ns:yang:iana-if-type">ianaift:ethernetCsmacd</type>
                 <enabled>true</enabled>
                 <ipv4 xmlns="urn:ietf:params:xml:ns:yang:ietf-ip">
                     <address>
                        <ip>{ip_address}</ip>
                        <netmask>{subnet_mask}</netmask>
                    </address>
                 </ipv4>
            </interface>
      </interfaces>
</config>
(3) exampl4.py
from device_info import ios_xe1
from ncclient import manager
if __name__ == '__main__':
       # NETCONF Config Template to use
       netconf_template = open("config-temp-ietf-interfaces.xml").read()
       # Build the XML Configuration to Send
       netconf_payload = netconf_template.format(int_name="GigabitEthernet2",
        int_desc="Configured by NETCONF",
        ip_address="10.255.255.1",
        subnet_mask="255.255.255.0"
         print("Configuration Payload:")
         print("----------------------")
         print(netconf_payload)
         with manager.connect(host=ios_xe1["address"], port=ios_xe1["port"],
                                           username=ios_xe1["username"],
                                           password=ios_xe1["password"],
                                           hostkey_verify=False) as m:
                                          result = m.edit_config(netconf_payload, 'candidate')
                                          print(result)
                                          reply = m.commit()
                                          print(reply)
Errors encountered are as follows:
File "/home/gayathri/Downloads/test/lib/python3.12/site-packages/ncclient/manager.py", line 270, in execute
return cls(self._session,
File "/home/gayathri/Downloads/test/lib/python3.12/site-packages/ncclient/operations/edit.py", line 76, in request
return self._request(node)
File "/home/gayathri/Downloads/test/lib/python3.12/site-packages/ncclient/operations/rpc.py", line 375, in _request
raise self._reply.error
ncclient.operations.rpc.RPCError: Unsupported capability :candidate
Please assist to rectify
GG
GJG
Hi Marcel,
Thank you for the support
I have adopted the following
(1) Enabled the candidate datastore by accessing the sandbox via SSH
(2) The code modification done is as follows:
result = m.edit_config(netconf_payload)
print(result)
reply = m.commit()
print(reply)
Successfully executed the code with the support given
GJG
Marcel Zehnder
Hi, the candidate datastore is not enabled by default, to enable it you need to configure it on the IOS-XE device using the command netconf-yang feature candidate-datastore:
1) SSH to you IOS-XE box and enter
conf t
do copy running-config startup-config
Details: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/prog/configuration/179/b_179_programmability_cg/m_179_prog_yang_netconf.html#id_78218
If you want to use the script without candidate datastore you need to edit the running datastore:
                                          result = m.edit_config(netconf_payload, 'running')
                                          print(result.data)
GJG
Hi Marcel,
print(result)
reply = m.commit()
print(reply)
GJG
