Java Application Monitoring Fundamentals; not the same flow map
SOLVED!
In this Lab I don't get the same flow map as described.
It should be this...
But I get this...
@henrik.janning.juul i saw you posted as 'solved' is this case or are you still seeing an issue with the learning lab please?
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
