Meraki Python SDK - UpdateNetworkVlan HTTP 403
BrandonSharp37516
Frequent Visitor
Frequent Visitor
Hello!
I am studying for DevNet associate and trying out the Meraki SDK on the DevNet SandBox. I am using the provided Dashboard API Key, however when trying to perform a PUT/update it returns a 403. I tried generating a API key from dashboard myself, but that returned a different list of Organizations. Am I missing something obvious? Any help would be appreciated!
Code sample: Error out with 403 on "meraki.vlans.update_network_vlan(updated_vlan)"
from meraki_sdk.meraki_sdk_client import MerakiSdkClient
from pprint import pprint
import json
token = 'SandboxToken'
# Create a new SDK client
meraki = MerakiSdkClient(token)
# Just an HTTP request to grab all Orgs
orgs = meraki.organizations.get_organizations()
pprint(orgs)
for org in orgs:
    if org['name'] == "DevNet Sandbox":
        orgId = org['id']
params = {}
params['organization_id'] = orgId
# Get all of a specific orgs networks
orgNetworks = meraki.networks.get_organization_networks(params)
pprint("-----------------Organization Networks-----------------")
pprint(orgNetworks)
for network in orgNetworks:
    if network['name'] == "DevNet Sandbox ALWAYS ON":
        netId = network['id']
pprint("-----------------Network ID-----------------")
pprint(netId)
# Get all of a specific Orgs specific networks vlans
vlans = meraki.vlans.get_network_vlans(netId)
pprint("-----------------VLANS-----------------")
pprint(vlans)
# Check the postman documentation for Cisco Meraki to understand.
# update_network_vlan requires two parameters (netId, vlanId) as well as an optional third paramter, which an object with the data you want to update
vlan = vlans[0]
vlan['name'] = "DevNet Tests"
updated_vlan = {}
updated_vlan['network_id'] = netId
updated_vlan['vlan_id'] = vlan['id']
updated_vlan['update_network_vlan'] = vlan
pprint("-----------------DICT TO SEND-----------------")
pprint(updated_vlan)
result_update_vlan = meraki.vlans.update_network_vlan(updated_vlan)
pprint("-----------------UPDATE RESULT-----------------")
result_get_vlans = meraki.vlans.get_network_vlans(netId)
pprint("-----------------UPDATE VERIFY-----------------")
pprint(result_get_vlans)
omz
Considering you have the correct API .. there is no network named "DevNet Sandbox ALWAYS ON" under ORG "DevNet Sandbox". Logged in to Meraki with username - [email protected] and password - i*******aki
Maybe it was deleted or something ... try recreating the network with a MX device to modify VLAN name.
The overall script is ok and it works if the network exists in the ORG.
Hey there, always on sandbox is read-only - you will be able to auth and get information - but not make changes. To do this, you would need to use the reservable sandbox's.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
