Missing Docker Container on lab Model Driven Telemetry
FulvioAllegretti36199
Community Member
Hi, was trying to go through the MDT lab and when I logged on the DEV box in theory the relative docker should be installed but it isn't:
(py3venv) [developer@devbox ~]$ docker ps
CONTAINER ID IMAGE COMMAND CREATED
STATUS PORTS NAMES
Am I doing something wrong?
@FulvioAllegretti36199 thanks for reporting this, working with our team to fix this up.
(py3venv) [developer@devbox ~]$ docker ps -a
CONTAINER ID        IMAGE               COMMAND             CREATED             STATUS              PORTS               NAMES
(py3venv) [developer@devbox ~]$ docker info | grep Contain
 Containers: 0
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Thanks, checked today, still the same:
[email protected]'s password:
Last login: Mon Mar 1 06:37:53 2021 from 192.168.254.11
NiclasAndersen
At todays date the issues is still not fixed.
I found a workaround by starting the containers when logged in to the devbox with the following commands:
to start the tig_mdt container in detached mode
docker run -d -p 3000:3000 -p 57500:57500 --name tig_mdt jeremycohoe/tig_mdt
and the yang-explorer in detached mode as well
docker run -d -p 8088:8088 --name yangexplorer hellt/yangexplorer-docker
it should look like in the screenshot
after the two commands are completed continue with the learning lab.
EDIT: the yang explorer don't work after adobe flash isn't supported in todays browsers
If you still want to play with telemetry and yang look at Yang Suite, it can do both.
start with this learning lab.
you also want to add * instead of localhost in the docker-compose.yml before running the docker-compose command, to be able to view the webpage in your browser.
if you still want to have access to the devbox cli while the containers are running use this command instead of the command used in the learning lab.
docker-compose up -d --build
and change the port used by the devices to the port specified in yang suite gRPC telemetry under protocols
Thanks for your details and workaround! I have asked ENG to look at this, as it was resolved and fixed.
Thanks again!
