Not able to connect to Firepower Management Center REST API
ppsilva02
I could reserve the lab, could enter, but anytime I try to access https://fmcrestapisandbox.cisco.com/api/api-explorer/ with the credentials supplied, I only get:
I'm using Chrome.
What can be the problem ?
5 Replies 5
jokearns1
please try on another firefox or safari (if you are on mac).
Joe
Sent from my Samsung Galaxy smartphone.
Thank you Joseph for you help.
Just tried Firefox and got the same answer from the server:
"code":403,
"description":"The server understood the request, but is refusing to fulfill it",
"homeRef":"/",
"reasonPhrase":"Forbidden",
"uri":"http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html#sec10.4.4"
It looks like the server is actively refusing the access.
do you have valid credentials? is your fmc sandbox reservation active? i would also try IE if you have it.
Joe
Thank you very much for you concern Joseph.
Yes I have now 40min left of the reservation time.
And I'm using the credentials I received by mail (which the same that appear on the "OUTPUT" window).
IE didn't worked either.
I'm giving up and will try it again tomorrow.
Thank you once again
Paulo
Salman111
I had same issue, I used firefox and it worked
