Problem connecting to SDWAN sandbox
ankit_b
Visitor
The lab information: Lab Network Address: devnetsandbox-emea-gwy.cisco.com:20206
I was able to connect to that address before when I was in the States, and I cannot do the same when I am trying from India.
The anyconnect logs:
4/22/19
    6:16:46 AM    Contacting devnetsandbox-emea-gwy.cisco.com:20206.
    6:17:16 AM    Connection attempt has failed.
    6:17:16 AM    Failed contacting devnetsandbox-emea-gwy.cisco.com.
I also have active lab-session if the support team needs to test.
Thanks in advance.
zowu
Hi Ankit,
You have an active VPN connection against the pod. As you know, there is only 1 VPN allowed per user basis.
Please let us know if you need to have current VPN session teardown and then you can have a new connection.
I did not have any active sessions on the newly one I created today and it still has the same problem.
The link to the newly created session is
  • Lab Network Address: devnetsandbox-emea-gwy.cisco.com:2020Thanks
