Problem Using Multi-IOS Virl LAB
rafavcc
Frequent Visitor
Frequent Visitor
Hello Everyone.
Yesterday I reserved a Multi-IOS lab to test a topology scenario, but once I logged into the VIRL server using any browser (Chrome/Edge/Firefox), the options "My Simulations" and the other option that is related to "Simulations" were grayed, so I could not click on them and launch the simulations. There is no way to work like this. I have followed a couple of youtube assisted VIRL server guides on how to access the system, and these options are on. What could be the reason of this?
I believe you need to login to VMMaestro credentials with guest/guest
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hope this helps.
Thanks, problem solved!
