Problems accessing the APIC in Sandbox ** resolved **
TomElgin49285
Frequent Visitor
Frequent Visitor
I just reserved an ACI sandbox and I'm able to connect to the VPN (with the info provided in the email) with no problem. I used the RDP (remote desktop) client in Windows 10 to connect to the DevBox. The next step of the process says to open a browser and https to an address. The problem is when I connect to the DevBox,  I don't see a browser on the Desktop. I tried searching for Internet Explorer with no luck. How do I access a browser in DevBox?
For those of you who run into this problem, be aware you won't be able to ping either the DevBoX IP or APIC AP from your laptop/Desktop. However (and I can't explain why), you will still be able to use Windows RDP to access the DevBox. From there, click on the "This PC" icon, expand the C: drive, expand the Program Files folder and look for Mozilla. Use Mozilla to access the APIC (the IPs for the DevBox and APIC are provided in the Sandbox instructions).
0 Replies 0
