10-28-2019 07:05 AM
I've reserved an Open NX-OS with Nexus 9Kv sandbox and received all the e-mails, but it still says that I need to reserve it to activate above the topology. I cannot ping any of the switch management IPs, even though the lab says that I should be able to.
Is this a known issue?
Solved! Go to Solution.
10-29-2019 01:24 AM
10-28-2019 07:38 AM
10-28-2019 07:56 AM - edited 10-28-2019 08:26 AM
I already read that and used the details to connect. I can also ping the other addresses, just not the switches.
Edit: the environment now shows as active, but the switches still time out when I try to ping.
10-28-2019 08:18 AM
10-28-2019 08:34 AM
Only the jump host is listed.
10-29-2019 12:59 AM
I ended and reserved the sandbox again, and there are still no switches listed.
10-29-2019 01:24 AM
10-29-2019 01:58 AM
Thank you; switches are building now 🙂
