Sandbox APIC-EM Lab device login doesn't seem to work...
jieyang28
Hi Everyone,
I am trying out the Sandbox APIC-EM MiniLab today, I can access the APIC-EM web gui fine, but Device Discovery failed, I then try to SSH to some of the lab devices, also failed.  The login credentials provided in the lab guide doesn't seem to work, any ideas?
Jie
6 Replies 6
jacoadam
Level 5
Level 5
Hello Jie,
Thanks for reaching out! Apologies for the delay in our response. Could you please let me know your DevNet username so that I can check on the status of your reservation?
Please let us know if you have additional questions!
Thanks!
Jacob
Hi Jacob,
My DevNet username is JIEYANG28, I am reserving MiniLab 2 now, and will see if it makes any differences.
Jie
Hello Jie,
I see that you reserved minilabs 2 and 3. Did you see issues with either of them? I am checking on minilab 1 to see if I can replicate your issues.
Thanks!
Jacob
Hi Jacob,
It seems only minilab 1 has the problem, 2 and 3 are fine, thanks.
Jie
Hi Jie,
Thanks for the update! We'll get minilab 1 repaired.
Thanks!
Jacob
Hello Jie,
Minilab 1 is now online!
Thanks!
Jacob
