SD-WAN Always On Connection Issue
piyush.singh02
Hi Team,
I am getting " Error: connect ECONNREFUSED 131.226.217.141:8443"   while trying to make session with SD-WAN instance https://sandbox-sdwan-1.cisco.com/
I could see request timeout while pinging from my system.
ping sandbox-sdwan-1.cisco.com
Pinging sandbox-sdwan-1.cisco.com [131.226.217.141] with 32 bytes of data:
Request timed out.
As this is always on instance I am not on Cisco VPN.
Appreciate your Responce.
Which postman collection are you using here, please? For this sandbox, I do not believe you should be passing port 8443.
https://developer.cisco.com/codeexchange/github/repo/CiscoDevNet/Postman-for-AlwaysOn-Cisco-SD-WANScreenshot 2020-07-30 at 11.46.19.pngScreenshot 2020-07-30 at 11.46.09.png
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
5 Replies 5
Hey there, it must have been a glitch. Looks ok now via UI and API
(venv) r$ date
Thu 30 Jul 2020 08:41:28 BST
(venv)  $ time python sdwan_auth.py
Login Success, 200
Getting Token
Token Success
real	0m0.992s
user	0m0.201s
sys	0m0.042s
Please try again.
Hope this helps.
Hi , Thanks for your reply.
Login is working for me too browser however when I am trying to make session via Postman API it's failing. Postman Request
Request Headers
Content-Typeapplication/x-www-form-urlencoded
Cache-Controlno-cache
Postman-Token2b9c2c38-9eb3-4d37-af2d-744e54147511
  • Request Body
    1.  j_username: "devnetuser"
    2.  j_password: "RG!_Yw919_83"
Thanks , It worked
I was directly trying to run authentication API.
Awesome - glad you are fixed up!
