SDWAN lab does not render GUI page
Corner Speed
Visitor
Cisco SD-WAN 19.2 Sandbox
  1. Go to 'URL'
  2. Login with credentials 'user/pass'
page loads for creds, once creds are entered just a blank web page. Been like this since last night. Tried chrome, FF and IE.
Any ideas?
7 Replies 7
Hello @Corner Speed the ENG team are aware of this happening, they are working on the fix. Please check back later.
Hope this helps.
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
Hello @Corner Speed ENG just asked me to test, this is working for me now (I am testing in FF). Please clear the browser cache and re-try.
Just tested with FF and Chrome, still same just a blank white page after authentication.
@Corner Speed Not sure what is the root cause of issue you are experiencing. ENG re-booted vManage and i am able to login via devnetuser on FF. I am wondering if there is a lot of activity on the sandbox and this is causing the UI to be slow. The API and UI share the same resources and many API calls are known to slow down the UI.
Try the reservation SD-WAN sandbox https://devnetsandbox.cisco.com/RM/Diagram/Index/c9679e49-6751-4f43-9bb4-9d7ee162b069?diagramType=Topology
having same problem just blank page either using FF or chrome, the link that @bigevilbeard share it leads to cisco sandbox lab and there is no sd-wan reserve sand box available
@adi.griyadi the sandbox ENG team are currently working a reservation issue with some sandbox - please check back later for the SD-WAN reservable sandbox.
Hope this helps.
Thank you @bigevilbeard i'll check regulary
