Secure DDoS Edge Protection Sandbox, interface in NCS540 is shutdown
pbagge
I'm running the Secure DDoS Edge Protection Sandbox but the interfaces in the NCS540 is shutdown and the user client is only a read only user.
RP/0/RP0/CPU0:NCS2_idle#sh run int tenGigE 0/0/0/4
Fri Mar 1 09:12:05.678 UTC
interface TenGigE0/0/0/4
ipv4 address 10.10.21.62 255.255.255.0
ipv6 enable
shutdown
flow ipv4 monitor DetectPro_Monitor_IPV4 sampler DetectPro_SMPL ingress
ipv4 access-group gtp ingress
RP/0/RP0/CPU0:NCS2_idle#sh run int tenGigE 0/0/0/5
Fri Mar 1 09:12:08.240 UTC
interface TenGigE0/0/0/5
ipv4 address 10.10.22.72 255.255.255.0
ipv6 enable
shutdown
Could someone fix the configuration of these interfaces?
The router is NCS2:
RP/0/RP0/CPU0:NCS2_idle#sh run int mgmtEth 0/RP0/CPU0/0
Fri Mar 1 09:13:42.750 UTC
interface MgmtEth0/RP0/CPU0/0
ipv4 address 10.10.20.52 255.255.255.0
thanks,
Patrik
zowu
We've reproduced the issue. Engineering team will have a upgrade recently to fix all NCS450 issues.
Ruben Cocheno
@pbagge
Outch!
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
