Troubles starting a lab
kamil.broz
Community Member
Hello, I have trouble starting any lab in the past 2 days. It is always stuck with an error.
Here is a link to my environment
IOS XE on Cat8kv-20231226T08042730
https:devnetsandbox.cisco.com/DevNet/sandboxes/pdpxsAHmdkWp/simplified
Is this just me or this happens to everyone?
Blue_Bird
Hi... The outage is now fixed. You can goahed and try to connect...
Reference: https://community.cisco.com/t5/devnet-sandbox/sandbox-lab-error/m-p/4985942#M9095
Best regards
******* If This Helps, Please Rate *******
6 Replies 6
azikocan97023
Community Member
I have a same problem 😞
Blue_Bird
Hello  kamil.broz and azikocan97023,
I think....Cisco has been  switcing to a new sandbox platform and it will take a few days  to reach a steady state.
Reference: https://community.cisco.com/t5/devnet-sandbox/active-environments-launched-from-this-blueprint-reached/td-p/4976470
Best regards
Is this the always on or the reservable version of IOS XE on Cat8kv?
Please mark this as helpful or solution accepted to help others
Connect with me https://bigevilbeard.github.io
This one was the reservable version but the Always on version didn't work either.
Blue_Bird
Best regards
Thanks, the lab is indeed now launching.
